CCS Programmers and Debuggers
| Featured Products | ||
ICD-U64 |
PRIME 8 |
Load-n-Go |
$75 |
$899 |
$199 |
| Low Cost In-Circuit USB Connected ICSP™ Debugger/Programmer | Eight Site ICSP™ Programmer | Hand held ICSP™ Debugger/Programmer |
Accelerate your product development
by quickly getting your hardware up and running with development tools that won't break your budget. Whether you are just bringing up a board in the lab, programming a small production run or updating products in the field, CCS offers a range of debugging and programming hardware designed to meet your needs and fit your budget.
- CCS C aware real time debugger integrated into the compiler IDE provides a robust and seamless debugging environment
- Debug at C source code level
- In-Circuit Serial Programming (ICSP™) for all devices that support ICSP
All CCS programmers and debuggers are supported by CCSLOAD, the free CCS programmer control software. CCSLOAD features a Windows user interface with extensive diagnostics, serialization, and security options as well as a command line interface that will run on Linux and Window's platforms.
A complete, low cost ICSP™ programmer/debugger for Microchip's PIC® MCUs and dsPIC® DSCs. ICD-U64 debug support covers all targets that have debug mode when used in conjunction with CCS IDE compilers. The unit also provides in-circuit serial programming support for all Flash chips.
A complete, low cost ICSP™ programmer/debugger for Microchip's PIC® MCUs and dsPIC® DSCs. ICD-S40 debug support covers all targets that have debug mode when used in conjunction with CCS IDE compilers. The unit also provides in-circuit serial programming support for all Flash chips.
A full featured ICSP™ device programmer/debugger that programs a wide range of parts including devices with Flash memory and features a ZIF socket for programming One-Time-Programmable (OTP) devices. It can be used standalone or while connected to a PC. It can also be used to debug software running on the target hardware when used in conjunction with the CCS C aware debugger.
A hand-held battery operated ICSP™ programmer/debugger for Microchip's PIC® MCUs and dsPIC® DSCs. Running on four AA batteries, this mobile programmer can go where no PC or laptop could go before. This device allows for quick field programming of targets with up to four firmware images. It can also be used as an in-circuit debugger with the CCS IDE.
The Prime 8 production programmer supports Microchip's PIC® MUCs and dsPIC® DSCs with eight in-circuit serial programming (ISCP™) jacks for high volume programming. Up to eight targets may be programmed at once. It can operate as a stand-alone production programmer with its SD card reader, making it ideal for production environments.
Tag-Connect is a cost saving production ICSP programming cable that eliminates the need for an ICSP connector on your product. Tag-Connect provides a direct pin-to-circuit connection, saving space and the cost of a connector on your PCB. The modular end works with existing ICD programmers on the market.
CCSLOAD Programmer Control Software
All CCS debuggers and programmers are supported by CCSLOAD, the free CCS programmer control software. CCSLOAD features a Windows user interface with extensive diagnostics and security options and a command line interface that will run on Linux and Window's platforms.
