Suddenly out of ROM
SkeeterHawk
Suddenly out of ROM
PostPosted: Mon Aug 04, 2025 11:37 am     Reply with quote
Hello programming Friends!
I had a weird issue that I can definitely work around, but I wanted to see if someone had an opinion as to what happened. I am using a PIC18F57Q84 with compiler version 5.114. I am loading an EEPROM with entries for a look-up table, so this is just a lot of monotonous code. I compiled about 7000 lines of code, and it said that I had used 52% of my available ROM. I wrote 2000 more lines, and the compiler "choked". Here is what it said
***Error 71 "C:\Pic....Main.c"Line 230(1,2); Out of ROM, A segment or the program is too large  WriteAllValuesToEEPROM
  Seg 00068-0FFFE, F1BC left, need 11EF0
  Seg 10000-1FFFE, 0000 left, need 11EF0
  Seg 00000-00002, 0000 left, need 11EF0 Reserved
  Seg 00004-00006, 0004 left, need 11EF0
  Seg 00008-00066, 0000 left, need 11EF0 Reserved
    1 Errors
Build Failed.
So, I commented out the extra lines so that it would compile, and it loaded the data into the EEPROM without a hitch.
Previously, about 2000 lines of code was taking around 10% of the ROM, so I expected it to be 62% when I got done writing, not to choke and say I was out of ROM. Is there a limit to how much ROM a single file can use or something?
Again, I can work around this regardless, but it would be good to know why I had 48% of my ROM magically vanish. Thanks for the input!
Life is too short to only write code in assembly...
Jerson
PostPosted: Mon Aug 04, 2025 8:19 pm     Reply with quote
Usually, what this means is the code / a part of it doest not fit into a memory segment. The way you can resolve this is to look into making certain parts SEPARATE (keyword)
PostPosted: Tue Aug 05, 2025 7:59 am     Reply with quote
Yes. Jerson is spot on.
The point is you don't have one single 'lump' of program memory, it is
divided into pages. Your code doing this job it being built as one 'lump',
so when you went over 50%, it will no longer fit into the page. Previously,
at 52%, you probably had several other bits occupying perhaps just a few
percent of this, that the compiler could put into another page, so you had this in one page and then just under 50% in the second. Now this single lump
will no longer fit.
You need to split it and it can then fit....
PostPosted: Tue Aug 05, 2025 9:52 am     Reply with quote
you may be able to break down the HUGE lookup table into 'segment fitting' chunks.
IE if it's a graphic database, consider segments for 'upper case', 'lower case' 'special symbols'. You'll need to add a simple 'test' to goto the correct table of course.
SkeeterHawk
Thanks for the input!!
PostPosted: Tue Aug 05, 2025 12:19 pm     Reply with quote
Thank you all for the input on this. I suspected that something like this is the issue, but I am a little surprised that I have never run into this before. So if I was writing this in assembly, would it just stop assembling the code unless I put a new Origin statement in the middle of it somewhere? Obviously this is a function of the hardware and would carry over into assembly as well, so I am just curious.
Thanks again for all of your input!! Very Happy
PostPosted: Tue Aug 05, 2025 12:40 pm     Reply with quote
If you go to PIC24 or DsPIC the problem goes away...
SkeeterHawk
PostPosted: Tue Aug 05, 2025 2:08 pm     Reply with quote
Good to know!! Thanks for the tip! I'd post a thumbs up...if there was one... Rolling Eyes
Re: Thanks for the input!!
PostPosted: Fri Aug 08, 2025 1:52 am     Reply with quote
It is actually quite hard in assembler. The default options do not allow code to
be larger than a page. You have to specify that thesis supported, and then
use long jumps or calls to cross between segments.
PostPosted: Sun Aug 10, 2025 2:17 pm     Reply with quote
this 'thread' got me wondering why it's 'hard to do'. 4 decades ago I did a fair amount of 8052 BASIC programming and recall they had some command ( XBY ??) that would access the ROM bank. 8052s went to HARVARD just like PICs.
I understand there's the 'jumping' from bank to bank issue ,but can't that be dealt with ?
OK my minds a tad fuzzy, being 40*C here, just curious that no one's made a 'driver' or 'patch' or 'function' or whatever you'd call the code .
PostPosted: Sun Aug 10, 2025 11:56 pm     Reply with quote
Absolutely.
It is not really 'hard', but slightly 'awkward'.
Build in two separate segments, and then use the long jump between.
The awkwardness comes from the default assembly behaviour, which is
to always build in one page. You have to explicitly override this.
In this case, it is not worth worrying about. Just split the table building
code into three or four parts, and the compiler can then juggle these with
the other routines to make the optimum fit.
