How to make chip run without ICD
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go
swb1
PostPosted: Sat May 13, 2006 7:47 am     Reply with quote
Question
After debugging how do you download the program so that the
chip will start and run without the ICD connected?
I am looking for the proper #device setting.
Thank You
Einstein
PostPosted: Tue May 30, 2006 6:25 am     Reply with quote
After debugging, the device had just been programmed by the ICD,
so it's ok and if your code is tested, the PIC is programmed Smile
PostPosted: Tue May 30, 2006 2:46 pm     Reply with quote
Here are several threads on this topic:
http://www.ccsinfo.com/forum/viewtopic.php?t=23937
http://www.ccsinfo.com/forum/viewtopic.php?t=23096
http://www.ccsinfo.com/forum/viewtopic.php?t=21380
http://www.ccsinfo.com/forum/viewtopic.php?t=18224
http://www.ccsinfo.com/forum/viewtopic.php?t=23719
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go All times are GMT - 6 Hours
