MCP23S08 returns 0x00 intermittingly
JerryR
PostPosted: Mon Jan 12, 2026 10:22 am     Reply with quote
Has anyone had an issue with a Microchip MCP23S08 port expander used as an input device, returning a 0x00 intermittingly.
Using pretty standard read code:
int8 ReadFrom_Thermo_Exp(void)
int8  received_Therm_data;
int8  dummy;
output_low(THERM_CS);
delay_us(50);
dummy= spi_xfer(CONTROL_REG_VAL_Read);
dummy= spi_xfer(GPIO_CONFIG_VAL);
received_Therm_data = spi_xfer(0);
delay_us(50);
output_high(THERM_CS);
delay_us(50);
return received_Therm_data;
Sampling at as slow as one second rate. SPI set up:
#use spi(MASTER, SPI1, BITS=8, BAUD=100000, MODE=0)
0x00 returned at random times from every 15 to every 100 reads.
Any help is appreciated!
PostPosted: Mon Jan 12, 2026 10:47 am     Reply with quote
What are your defined values for
and
GPIO_CONFIG_VAL
What else do you do on the SPI bus between the commands?.
What PIC?.
What compiler version.
Honestly an intermittent behaviour suggests a hardware glitch.
PostPosted: Mon Jan 12, 2026 6:47 pm     Reply with quote
just thinking out load here but...
I was thinking maybe no pullups on the inputs, might cause a '0' or two, but ALL '0's does seem 'weird'.
Have you tested with a known pattern as the inputs ( ie HARD wired 1s and 0s ).
JerryR
PostPosted: Tue Jan 13, 2026 8:20 am     Reply with quote
Solved
Well, there was no issue digitally. Non-synchronous noise on input on MCP23S08 actually was triggering a 0x00 output.
Thanks so much for your consideration and sanity check.
Best regards
PostPosted: Tue Jan 13, 2026 10:41 am     Reply with quote
Nice to hear you FOUND the cause ! It took me 2 MONTHS to discover 'crosstalk' on a main span of Bell telephone cables was causing 'my' problem, ONLY between 2 and 3 AM, Sunday mornings.
PostPosted: Wed Jan 14, 2026 1:54 am     Reply with quote
Well done. 'Glitch' was exactly right!. It sounded like that..... Very Happy
