allenhuffman
Joined: 17 Jun 2019 Posts: 537 Location: Des Moines, Iowa, USA
Alternative I2C library for CCS? |
Posted: Mon Sep 09, 2019 10:18 am |
Does anyone know of an alternative I2C library that could be used with the CCS IDE/compiler? I've found implementations for PIC in general, and MPLAB, but I am trying to find something I could integrate into existing code to see if behavior of an issue we have been having might change. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ? |
Joined: 01 Jul 2010 Posts: 9108 Location: Greensville,Ontario
Posted: Mon Sep 09, 2019 10:35 am |
I've not had any issues but it'd be easy enough to dump the listing, see how CCS codes, then cut you own 'drivers' and 'tweak' them for whatever device you're using. Once you've got the machine code, you simply check for correct timing and sequences of operations.
I've seen in the past so called 'I2C' compatible devices that need specific timing requirements. Course that was 2 decades ago, preCCS, when I used assembler.
Is there a specific device ? as every RTC, EEPROM have always worked with CCS drivers. Remember.. the CCS drivers tend to be 'generic'.
allenhuffman
Posted: Mon Sep 09, 2019 10:42 am |
temtronic wrote: |
The issue is on a bus with three PIC-based devices connected to a PC via FTDI I2C driver. At some point, we get a bus hang. It appears one of the PIC devices misses a clock pulse and creates the issue.
We have seen some oddness with the spacing of the clock pulses the FTDI part generates and have a dialog with FTDI on this, also. (The FTDI drivers do not support the bus clear (I2C spec 3.1.16).
Since we can't generate the clock pulses from the PC, we are now trying to do so from the PIC side. I started researching how to do this today.
Meanwhile, I've been asked to find an alternate I2C implementation that we can use to try to recreate this.
It's been a fun last few weeks. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
