Alternative I2C library for CCS?
allenhuffman
PostPosted: Mon Sep 09, 2019 10:18 am     Reply with quote
Does anyone know of an alternative I2C library that could be used with the CCS IDE/compiler? I've found implementations for PIC in general, and MPLAB, but I am trying to find something I could integrate into existing code to see if behavior of an issue we have been having might change.
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
PostPosted: Mon Sep 09, 2019 10:30 am     Reply with quote
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=57119
PostPosted: Mon Sep 09, 2019 10:35 am     Reply with quote
I've not had any issues but it'd be easy enough to dump the listing, see how CCS codes, then cut you own 'drivers' and 'tweak' them for whatever device you're using. Once you've got the machine code, you simply check for correct timing and sequences of operations.
I've seen in the past so called 'I2C' compatible devices that need specific timing requirements. Course that was 2 decades ago, preCCS, when I used assembler.
Is there a specific device ? as every RTC, EEPROM have always worked with CCS drivers. Remember.. the CCS drivers tend to be 'generic'.
Jay
allenhuffman
PostPosted: Mon Sep 09, 2019 10:42 am     Reply with quote
Jay
The issue is on a bus with three PIC-based devices connected to a PC via FTDI I2C driver. At some point, we get a bus hang. It appears one of the PIC devices misses a clock pulse and creates the issue.
We have seen some oddness with the spacing of the clock pulses the FTDI part generates and have a dialog with FTDI on this, also. (The FTDI drivers do not support the bus clear (I2C spec 3.1.16).
Since we can't generate the clock pulses from the PC, we are now trying to do so from the PIC side. I started researching how to do this today.
Meanwhile, I've been asked to find an alternate I2C implementation that we can use to try to recreate this.
It's been a fun last few weeks.
PostPosted: Mon Sep 09, 2019 11:42 am     Reply with quote
In addition to the software driver that I posted above, here are some
hardware i2c alternate libraries:
http://www.ccsinfo.com/forum/viewtopic.php?t=22105
http://www.ccsinfo.com/forum/viewtopic.php?t=21456
