		| Author | Message |
		| scanan
				| [SOLVED] Software SPI with PIC18F65K80 |
				|  Posted: Fri Nov 10, 2017 7:52 am |   |
				| I have a problem with software spi. I am using PIC18K65K80
 CCS compiler version 5.062
 here is my code
  	  | Code: |  	  | #include <18F65K80.h>
 #device adc=8
 #FUSES PLLEN,VREGSLEEP,SOSC_DIG,NOXINST,INTRC_IO,NOFCMEN,NOIESO //1
 #FUSES PUT,NOBROWNOUT,WDT1024,NOWDT //2
 #FUSES CANE,MSSPMSK7,NOMCLR //3
 #FUSES NOSTVREN,BBSIZ2K,NODEBUG //4
 #FUSES PROTECT,NOCPB,NOCPD //5
 #FUSES NOWRT,NOWRTC,NOWRTB,NOWRTD,  //6
 #FUSES NOEBTR,NOEBTRB //7
 #use delay(clock=64Mhz)
 #use spi(MASTER,FORCE_SW,MODE=0,BAUD=100000,DO=PIN_E0,CLK=PIN_E1, ENABLE=PIN_E2, BITS=16,STREAM=myspi)
 #use fast_io(A)
 #use fast_io(B)
 #use fast_io(C)
 #use fast_io(D)
 #use fast_io(E)
 #use fast_io(F)
 #use fast_io(G)
 #define INPUT_    1
 #define OUTPUT_ 0
 #define portA 0
 #define portB 1
 #define portC 2
 #define portD 3
 #define portE 4
 #define portF 5
 #define portG 6
 union {
 unsigned int8 tris[9];
 struct IO_RX{
 BOOLEAN iChiprefreshLED;    //A0
 BOOLEAN modulepowerNRF;     //A1
 BOOLEAN buzzer;          //A2
 BOOLEAN modulerefreshLED;  //A3
 BOOLEAN pinA4;               //A4
 BOOLEAN emergencyLED;        //A5
 BOOLEAN cpuLED;              //A6
 BOOLEAN commLED;             //A7
 BOOLEAN moduleDR1;          //B0
 BOOLEAN moduleDR2;          //B1
 BOOLEAN startrelayfeedback1;  //B2
 BOOLEAN startrelayfeedback2;  //B3
 BOOLEAN IRLED;              //B4
 BOOLEAN errorLED;           //B5
 BOOLEAN PICkitCLK;            //B6
 BOOLEAN PICkitDATA;           //B7
 BOOLEAN dipSW0;              //C0
 BOOLEAN iChipplugged;         //C1
 BOOLEAN pinC2;               //C2
 BOOLEAN i2cSCL;              //C3
 BOOLEAN i2cSDA;              //C4
 BOOLEAN eepromWP;            //C5
 BOOLEAN testpin;             //C6
 BOOLEAN modulepowerPA;       //C7
 BOOLEAN moduleCSD;          //D0
 BOOLEAN moduleCPS;          //D1
 BOOLEAN moduleCTX;          //D2
 BOOLEAN modulePWRUP;        //D3
 BOOLEAN moduleCE;           //D4
 BOOLEAN moduleCS;           //D5
 BOOLEAN moduleCLK1;         //D6
 BOOLEAN moduleDATA;         //D7
 BOOLEAN DIN;          //E0
 BOOLEAN CLK;          //E1
 BOOLEAN CS;           //E2
 BOOLEAN MCLR;               //E3
 BOOLEAN CANRX2;             //E4
 BOOLEAN CANTX2;             //E5
 BOOLEAN START1;              //E6
 BOOLEAN START2;              //E7
 BOOLEAN pinF0;              //F0
 BOOLEAN pinF1;        //F1
 BOOLEAN pinF2;                 //F2
 BOOLEAN relaysenable;              //F3
 BOOLEAN dipSW2;              //F4
 BOOLEAN dipSW3;            //F5
 BOOLEAN Rx2Txteachbutton;             //F6
 BOOLEAN Tx2Rxteachbutton;             //F7
 BOOLEAN rs232RX;                //G0
 BOOLEAN dipSW4;              //G1
 BOOLEAN dipSW5;                //G2
 BOOLEAN rs232TX;              //G3
 BOOLEAN dipSW6;      //G4
 BOOLEAN pinG5;               //G5
 BOOLEAN pinG6;              //G6
 BOOLEAN pinG7;              //G7
 }bit;
 } trisval;
 void set_tris_(void)
 set_tris_a(trisval.tris[portA]);
 set_tris_b(trisval.tris[portB]);
 set_tris_c(trisval.tris[portC]);
 set_tris_d(trisval.tris[portD]);
 set_tris_e(trisval.tris[portE]);
 set_tris_f(trisval.tris[portF]);
 set_tris_g(trisval.tris[portG]);
 void set_trisvalue(void)
 trisval.bit.iChiprefreshLED=OUTPUT_;    //A0
 trisval.bit.modulepowerNRF=OUTPUT_;     //A1
 trisval.bit.buzzer=OUTPUT_;             //A2
 trisval.bit.modulerefreshLED=OUTPUT_;   //A3
 trisval.bit.pinA4=OUTPUT_;              //A4
 trisval.bit.emergencyLED=OUTPUT_;       //A5
 trisval.bit.cpuLED=OUTPUT_;             //A6
 trisval.bit.commLED=OUTPUT_;            //A7
 trisval.bit.moduleDR1=INPUT_;            //B0
 trisval.bit.moduleDR2=OUTPUT_;           //B1
 trisval.bit.startrelayfeedback1=INPUT_;  //B2
 trisval.bit.startrelayfeedback2=INPUT_;  //B3
 trisval.bit.IRLED=OUTPUT_;               //B4
 trisval.bit.errorLED=OUTPUT_;            //B5
 trisval.bit.PICkitCLK=INPUT_;            //B6
 trisval.bit.PICkitDATA=INPUT_;           //B7
 trisval.bit.dipsw0=INPUT_;              //C0
 trisval.bit.iChipplugged=INPUT_;        //C1
 trisval.bit.pinC2=OUTPUT_;              //C2
 trisval.bit.i2cSCL=INPUT_;              //C3
 trisval.bit.i2cSDA=INPUT_;              //C4
 trisval.bit.eepromWP=OUTPUT_;           //C5
 trisval.bit.testpin=OUTPUT_;            //C6
 trisval.bit.modulepowerPA=OUTPUT_;      //C7
 trisval.bit.moduleCSD=OUTPUT_;          //D0
 trisval.bit.moduleCPS=OUTPUT_;          //D1
 trisval.bit.moduleCTX=OUTPUT_;          //D2
 trisval.bit.modulePWRUP=OUTPUT_;        //D3
 trisval.bit.moduleCE=OUTPUT_;           //D4
 trisval.bit.moduleCS=OUTPUT_;           //D5
 trisval.bit.moduleCLK1=OUTPUT_;         //D6
 trisval.bit.moduleDATA=INPUT_;          //D7
 trisval.bit.DIN=OUTPUT_;          //E0
 trisval.bit.CLK=OUTPUT_;          //E1
 trisval.bit.CS=OUTPUT_;           //E2
 trisval.bit.MCLR=OUTPUT_;               //E3
 trisval.bit.CANRX2=INPUT_;              //E4
 trisval.bit.CANTX2=OUTPUT_;             //E5
 trisval.bit.start1=OUTPUT_;             //E6
 trisval.bit.start2=OUTPUT_;             //E7
 trisval.bit.pinF0=OUTPUT_;              //F0
 trisval.bit.pinF1=OUTPUT_;              //F1
 trisval.bit.pinF2=OUTPUT_;              //F2
 trisval.bit.relaysenable=OUTPUT_;       //F3
 trisval.bit.dipSW2=INPUT_;              //F4
 trisval.bit.dipSW3=INPUT_;              //F5
 trisval.bit.Rx2Txteachbutton=INPUT_;    //F6
 trisval.bit.Tx2Rxteachbutton=INPUT_;    //F7
 trisval.bit.rs232Rx=INPUT_;            //G0
 trisval.bit.dipSW4=INPUT_;             //G1
 trisval.bit.dipSW5=INPUT_;             //G2
 trisval.bit.rs232Tx=OUTPUT_;           //G3
 trisval.bit.dipSW6=INPUT_;             //G4
 trisval.bit.pinG5=OUTPUT_;       //G5
 trisval.bit.pinG6=OUTPUT_;       //G6
 trisval.bit.pinG7=OUTPUT_;       //G7
 set_trisvalue();
 set_tris_();
 setup_adc(ADC_OFF);
 setup_psp(PSP_DISABLED);
 setup_timer_0(RTCC_INTERNAL|RTCC_DIV_4);// TIMER0 8.1ms rsesolution
 setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
 setup_vref(FALSE);
 setup_low_volt_detect(FALSE);
 setup_oscillator(OSC_16MHZ|OSC_PLL_ON);
 EXT_INT_EDGE(0,L_TO_H);
 enable_interrupts(INT_EXT);
 disable_interrupts(GLOBAL);
 loop:
 spi_xfer(myspi,0xAAAA,16);
 delay_ms(200);
 goto loop;
 I see nothing on PIN_E0, PIN_E1,PIN_E2 on my scope, any suggestion ?
 Dr Suleyman CANAN
 R&D Electronic Engineer
 https://suleymancanan.wordpress.com
 Do whatever you do with amateur spirit -
 But always feel professional.
		| PCM programmer
				|  Posted: Fri Nov 10, 2017 8:17 am |   |
				|  	  | Quote: |  	  | void main(void) {
 set_trisvalue();
 set_tris_();
 Post the code for the lines shown in bold.
		| scanan
				|  Posted: Mon Nov 13, 2017 3:06 am |   |
				|  	  | PCM programmer wrote: |  	  |  	  | Quote: |  	  | void main(void) {
 set_trisvalue();
 set_tris_();
 the functions are added..
 Dr Suleyman CANAN
		| PCM programmer
				|  Posted: Mon Nov 13, 2017 4:10 pm |   |
				| You might not see it on your scope because you're using a slow repetition rate in your while() loop.  Try this program which has a much faster loop
 speed:
 #device adc=8
 spi_xfer(myspi, 0x5555, 16);
 delay_us(200);
		| scanan
				|  Posted: Tue Nov 14, 2017 1:41 am |   |
				|  	  | PCM programmer wrote: |  	  | You might not see it on your scope because you're using a slow repetition rate in your while() loop.  Try this program which has a much faster loop
 speed:
 You're right my loop was too slow,
 Many Thanks, problem solved.
 Dr Suleyman CANAN
 | You cannot post new topics in this forum You cannot reply to topics in this forum
