Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
[SOLVED] Software SPI with PIC18F65K80
scanan
PostPosted: Fri Nov 10, 2017 7:52 am     Reply with quote
I have a problem with software spi.
I am using PIC18K65K80
CCS compiler version 5.062
here is my code
#include <18F65K80.h>
#device adc=8
#FUSES PLLEN,VREGSLEEP,SOSC_DIG,NOXINST,INTRC_IO,NOFCMEN,NOIESO //1
#FUSES PUT,NOBROWNOUT,WDT1024,NOWDT //2
#FUSES CANE,MSSPMSK7,NOMCLR //3
#FUSES NOSTVREN,BBSIZ2K,NODEBUG //4
#FUSES PROTECT,NOCPB,NOCPD //5
#FUSES NOWRT,NOWRTC,NOWRTB,NOWRTD,  //6
#FUSES NOEBTR,NOEBTRB //7
#use delay(clock=64Mhz)
#use spi(MASTER,FORCE_SW,MODE=0,BAUD=100000,DO=PIN_E0,CLK=PIN_E1, ENABLE=PIN_E2, BITS=16,STREAM=myspi)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
#use fast_io(F)
#use fast_io(G)
#define INPUT_    1
#define OUTPUT_ 0
#define portA 0
#define portB 1
#define portC 2
#define portD 3
#define portE 4
#define portF 5
#define portG 6
union {
           unsigned int8 tris[9];
struct IO_RX{
           BOOLEAN iChiprefreshLED;    //A0
           BOOLEAN modulepowerNRF;     //A1
           BOOLEAN buzzer;          //A2
           BOOLEAN modulerefreshLED;  //A3
           BOOLEAN pinA4;               //A4
           BOOLEAN emergencyLED;        //A5
           BOOLEAN cpuLED;              //A6
           BOOLEAN commLED;             //A7
           BOOLEAN moduleDR1;          //B0
           BOOLEAN moduleDR2;          //B1
           BOOLEAN startrelayfeedback1;  //B2
           BOOLEAN startrelayfeedback2;  //B3
           BOOLEAN IRLED;              //B4
           BOOLEAN errorLED;           //B5
           BOOLEAN PICkitCLK;            //B6
           BOOLEAN PICkitDATA;           //B7
           BOOLEAN dipSW0;              //C0
           BOOLEAN iChipplugged;         //C1
           BOOLEAN pinC2;               //C2
           BOOLEAN i2cSCL;              //C3
           BOOLEAN i2cSDA;              //C4
           BOOLEAN eepromWP;            //C5
           BOOLEAN testpin;             //C6
           BOOLEAN modulepowerPA;       //C7
           BOOLEAN moduleCSD;          //D0
           BOOLEAN moduleCPS;          //D1
           BOOLEAN moduleCTX;          //D2
           BOOLEAN modulePWRUP;        //D3
           BOOLEAN moduleCE;           //D4
           BOOLEAN moduleCS;           //D5
           BOOLEAN moduleCLK1;         //D6
           BOOLEAN moduleDATA;         //D7
           BOOLEAN DIN;          //E0
           BOOLEAN CLK;          //E1
           BOOLEAN CS;           //E2
           BOOLEAN MCLR;               //E3
           BOOLEAN CANRX2;             //E4
           BOOLEAN CANTX2;             //E5
           BOOLEAN START1;              //E6
           BOOLEAN START2;              //E7
           BOOLEAN pinF0;              //F0
           BOOLEAN pinF1;        //F1
           BOOLEAN pinF2;                 //F2
           BOOLEAN relaysenable;              //F3
           BOOLEAN dipSW2;              //F4
           BOOLEAN dipSW3;            //F5
           BOOLEAN Rx2Txteachbutton;             //F6
           BOOLEAN Tx2Rxteachbutton;             //F7
           BOOLEAN rs232RX;                //G0
           BOOLEAN dipSW4;              //G1
           BOOLEAN dipSW5;                //G2
           BOOLEAN rs232TX;              //G3
           BOOLEAN dipSW6;      //G4
           BOOLEAN pinG5;               //G5
           BOOLEAN pinG6;              //G6
           BOOLEAN pinG7;              //G7
}bit;
} trisval;
void set_tris_(void)
   set_tris_a(trisval.tris[portA]);
   set_tris_b(trisval.tris[portB]);
   set_tris_c(trisval.tris[portC]);
   set_tris_d(trisval.tris[portD]);
   set_tris_e(trisval.tris[portE]);
   set_tris_f(trisval.tris[portF]);
   set_tris_g(trisval.tris[portG]);
void set_trisvalue(void)
        trisval.bit.iChiprefreshLED=OUTPUT_;    //A0
        trisval.bit.modulepowerNRF=OUTPUT_;     //A1
        trisval.bit.buzzer=OUTPUT_;             //A2
        trisval.bit.modulerefreshLED=OUTPUT_;   //A3
        trisval.bit.pinA4=OUTPUT_;              //A4
        trisval.bit.emergencyLED=OUTPUT_;       //A5
        trisval.bit.cpuLED=OUTPUT_;             //A6
        trisval.bit.commLED=OUTPUT_;            //A7
        trisval.bit.moduleDR1=INPUT_;            //B0
        trisval.bit.moduleDR2=OUTPUT_;           //B1
        trisval.bit.startrelayfeedback1=INPUT_;  //B2
        trisval.bit.startrelayfeedback2=INPUT_;  //B3
        trisval.bit.IRLED=OUTPUT_;               //B4
        trisval.bit.errorLED=OUTPUT_;            //B5
        trisval.bit.PICkitCLK=INPUT_;            //B6
        trisval.bit.PICkitDATA=INPUT_;           //B7
        trisval.bit.dipsw0=INPUT_;              //C0
        trisval.bit.iChipplugged=INPUT_;        //C1
        trisval.bit.pinC2=OUTPUT_;              //C2
        trisval.bit.i2cSCL=INPUT_;              //C3
        trisval.bit.i2cSDA=INPUT_;              //C4
        trisval.bit.eepromWP=OUTPUT_;           //C5
        trisval.bit.testpin=OUTPUT_;            //C6
        trisval.bit.modulepowerPA=OUTPUT_;      //C7
        trisval.bit.moduleCSD=OUTPUT_;          //D0
        trisval.bit.moduleCPS=OUTPUT_;          //D1
        trisval.bit.moduleCTX=OUTPUT_;          //D2
        trisval.bit.modulePWRUP=OUTPUT_;        //D3
        trisval.bit.moduleCE=OUTPUT_;           //D4
        trisval.bit.moduleCS=OUTPUT_;           //D5
        trisval.bit.moduleCLK1=OUTPUT_;         //D6
        trisval.bit.moduleDATA=INPUT_;          //D7
        trisval.bit.DIN=OUTPUT_;          //E0
        trisval.bit.CLK=OUTPUT_;          //E1
        trisval.bit.CS=OUTPUT_;           //E2
        trisval.bit.MCLR=OUTPUT_;               //E3
        trisval.bit.CANRX2=INPUT_;              //E4
        trisval.bit.CANTX2=OUTPUT_;             //E5
        trisval.bit.start1=OUTPUT_;             //E6
        trisval.bit.start2=OUTPUT_;             //E7
        trisval.bit.pinF0=OUTPUT_;              //F0
        trisval.bit.pinF1=OUTPUT_;              //F1
        trisval.bit.pinF2=OUTPUT_;              //F2
        trisval.bit.relaysenable=OUTPUT_;       //F3
        trisval.bit.dipSW2=INPUT_;              //F4
        trisval.bit.dipSW3=INPUT_;              //F5
        trisval.bit.Rx2Txteachbutton=INPUT_;    //F6
        trisval.bit.Tx2Rxteachbutton=INPUT_;    //F7
        trisval.bit.rs232Rx=INPUT_;            //G0
        trisval.bit.dipSW4=INPUT_;             //G1
        trisval.bit.dipSW5=INPUT_;             //G2
        trisval.bit.rs232Tx=OUTPUT_;           //G3
        trisval.bit.dipSW6=INPUT_;             //G4
        trisval.bit.pinG5=OUTPUT_;       //G5
        trisval.bit.pinG6=OUTPUT_;       //G6
        trisval.bit.pinG7=OUTPUT_;       //G7
  set_trisvalue();
  set_tris_();
    setup_adc(ADC_OFF);
    setup_psp(PSP_DISABLED);
    setup_timer_0(RTCC_INTERNAL|RTCC_DIV_4);// TIMER0 8.1ms rsesolution
    setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
    setup_vref(FALSE);
    setup_low_volt_detect(FALSE);
    setup_oscillator(OSC_16MHZ|OSC_PLL_ON);
    EXT_INT_EDGE(0,L_TO_H);
    enable_interrupts(INT_EXT);
    disable_interrupts(INT_TIMER1);
    disable_interrupts(GLOBAL);
loop:
        spi_xfer(myspi,0xAAAA,16);
delay_ms(200);
goto loop;
I see nothing on PIN_E0, PIN_E1,PIN_E2 on my scope, any suggestion ?
Dr Suleyman CANAN
R&D Electronic Engineer
https://suleymancanan.wordpress.com
Do whatever you do with amateur spirit -
But always feel professional.
PostPosted: Fri Nov 10, 2017 8:17 am     Reply with quote
set_trisvalue();
set_tris_();
Post the code for the lines shown in bold.
scanan
PostPosted: Mon Nov 13, 2017 3:06 am     Reply with quote
PCM programmer wrote:
set_trisvalue();
set_tris_();
the functions are added..
Dr Suleyman CANAN
PostPosted: Mon Nov 13, 2017 4:10 pm     Reply with quote
You might not see it on your scope because you're using a slow repetition
rate in your while() loop. Try this program which has a much faster loop
speed:
#device adc=8
   spi_xfer(myspi, 0x5555, 16);
   delay_us(200);
scanan
PostPosted: Tue Nov 14, 2017 1:41 am     Reply with quote
speed:
You're right my loop was too slow,
Many Thanks, problem solved.
Dr Suleyman CANAN
