scanan
| [SOLVED] Software SPI with PIC18F65K80 |
Posted: Fri Nov 10, 2017 7:52 am |
I have a problem with software spi.
I am using PIC18K65K80
CCS compiler version 5.062
here is my code
#include <18F65K80.h>
#device adc=8
#FUSES PLLEN,VREGSLEEP,SOSC_DIG,NOXINST,INTRC_IO,NOFCMEN,NOIESO //1
#FUSES PUT,NOBROWNOUT,WDT1024,NOWDT //2
#FUSES CANE,MSSPMSK7,NOMCLR //3
#FUSES NOSTVREN,BBSIZ2K,NODEBUG //4
#FUSES PROTECT,NOCPB,NOCPD //5
#FUSES NOWRT,NOWRTC,NOWRTB,NOWRTD, //6
#FUSES NOEBTR,NOEBTRB //7
#use delay(clock=64Mhz)
#use spi(MASTER,FORCE_SW,MODE=0,BAUD=100000,DO=PIN_E0,CLK=PIN_E1, ENABLE=PIN_E2, BITS=16,STREAM=myspi)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
#use fast_io(F)
#use fast_io(G)
#define INPUT_ 1
#define OUTPUT_ 0
#define portA 0
#define portB 1
#define portC 2
#define portD 3
#define portE 4
#define portF 5
#define portG 6
union {
unsigned int8 tris[9];
struct IO_RX{
BOOLEAN iChiprefreshLED; //A0
BOOLEAN modulepowerNRF; //A1
BOOLEAN buzzer; //A2
BOOLEAN modulerefreshLED; //A3
BOOLEAN pinA4; //A4
BOOLEAN emergencyLED; //A5
BOOLEAN cpuLED; //A6
BOOLEAN commLED; //A7
BOOLEAN moduleDR1; //B0
BOOLEAN moduleDR2; //B1
BOOLEAN startrelayfeedback1; //B2
BOOLEAN startrelayfeedback2; //B3
BOOLEAN IRLED; //B4
BOOLEAN errorLED; //B5
BOOLEAN PICkitCLK; //B6
BOOLEAN PICkitDATA; //B7
BOOLEAN dipSW0; //C0
BOOLEAN iChipplugged; //C1
BOOLEAN pinC2; //C2
BOOLEAN i2cSCL; //C3
BOOLEAN i2cSDA; //C4
BOOLEAN eepromWP; //C5
BOOLEAN testpin; //C6
BOOLEAN modulepowerPA; //C7
BOOLEAN moduleCSD; //D0
BOOLEAN moduleCPS; //D1
BOOLEAN moduleCTX; //D2
BOOLEAN modulePWRUP; //D3
BOOLEAN moduleCE; //D4
BOOLEAN moduleCS; //D5
BOOLEAN moduleCLK1; //D6
BOOLEAN moduleDATA; //D7
BOOLEAN DIN; //E0
BOOLEAN CLK; //E1
BOOLEAN CS; //E2
BOOLEAN MCLR; //E3
BOOLEAN CANRX2; //E4
BOOLEAN CANTX2; //E5
BOOLEAN START1; //E6
BOOLEAN START2; //E7
BOOLEAN pinF0; //F0
BOOLEAN pinF1; //F1
BOOLEAN pinF2; //F2
BOOLEAN relaysenable; //F3
BOOLEAN dipSW2; //F4
BOOLEAN dipSW3; //F5
BOOLEAN Rx2Txteachbutton; //F6
BOOLEAN Tx2Rxteachbutton; //F7
BOOLEAN rs232RX; //G0
BOOLEAN dipSW4; //G1
BOOLEAN dipSW5; //G2
BOOLEAN rs232TX; //G3
BOOLEAN dipSW6; //G4
BOOLEAN pinG5; //G5
BOOLEAN pinG6; //G6
BOOLEAN pinG7; //G7
}bit;
} trisval;
void set_tris_(void)
set_tris_a(trisval.tris[portA]);
set_tris_b(trisval.tris[portB]);
set_tris_c(trisval.tris[portC]);
set_tris_d(trisval.tris[portD]);
set_tris_e(trisval.tris[portE]);
set_tris_f(trisval.tris[portF]);
set_tris_g(trisval.tris[portG]);
void set_trisvalue(void)
trisval.bit.iChiprefreshLED=OUTPUT_; //A0
trisval.bit.modulepowerNRF=OUTPUT_; //A1
trisval.bit.buzzer=OUTPUT_; //A2
trisval.bit.modulerefreshLED=OUTPUT_; //A3
trisval.bit.pinA4=OUTPUT_; //A4
trisval.bit.emergencyLED=OUTPUT_; //A5
trisval.bit.cpuLED=OUTPUT_; //A6
trisval.bit.commLED=OUTPUT_; //A7
trisval.bit.moduleDR1=INPUT_; //B0
trisval.bit.moduleDR2=OUTPUT_; //B1
trisval.bit.startrelayfeedback1=INPUT_; //B2
trisval.bit.startrelayfeedback2=INPUT_; //B3
trisval.bit.IRLED=OUTPUT_; //B4
trisval.bit.errorLED=OUTPUT_; //B5
trisval.bit.PICkitCLK=INPUT_; //B6
trisval.bit.PICkitDATA=INPUT_; //B7
trisval.bit.dipsw0=INPUT_; //C0
trisval.bit.iChipplugged=INPUT_; //C1
trisval.bit.pinC2=OUTPUT_; //C2
trisval.bit.i2cSCL=INPUT_; //C3
trisval.bit.i2cSDA=INPUT_; //C4
trisval.bit.eepromWP=OUTPUT_; //C5
trisval.bit.testpin=OUTPUT_; //C6
trisval.bit.modulepowerPA=OUTPUT_; //C7
trisval.bit.moduleCSD=OUTPUT_; //D0
trisval.bit.moduleCPS=OUTPUT_; //D1
trisval.bit.moduleCTX=OUTPUT_; //D2
trisval.bit.modulePWRUP=OUTPUT_; //D3
trisval.bit.moduleCE=OUTPUT_; //D4
trisval.bit.moduleCS=OUTPUT_; //D5
trisval.bit.moduleCLK1=OUTPUT_; //D6
trisval.bit.moduleDATA=INPUT_; //D7
trisval.bit.DIN=OUTPUT_; //E0
trisval.bit.CLK=OUTPUT_; //E1
trisval.bit.CS=OUTPUT_; //E2
trisval.bit.MCLR=OUTPUT_; //E3
trisval.bit.CANRX2=INPUT_; //E4
trisval.bit.CANTX2=OUTPUT_; //E5
trisval.bit.start1=OUTPUT_; //E6
trisval.bit.start2=OUTPUT_; //E7
trisval.bit.pinF0=OUTPUT_; //F0
trisval.bit.pinF1=OUTPUT_; //F1
trisval.bit.pinF2=OUTPUT_; //F2
trisval.bit.relaysenable=OUTPUT_; //F3
trisval.bit.dipSW2=INPUT_; //F4
trisval.bit.dipSW3=INPUT_; //F5
trisval.bit.Rx2Txteachbutton=INPUT_; //F6
trisval.bit.Tx2Rxteachbutton=INPUT_; //F7
trisval.bit.rs232Rx=INPUT_; //G0
trisval.bit.dipSW4=INPUT_; //G1
trisval.bit.dipSW5=INPUT_; //G2
trisval.bit.rs232Tx=OUTPUT_; //G3
trisval.bit.dipSW6=INPUT_; //G4
trisval.bit.pinG5=OUTPUT_; //G5
trisval.bit.pinG6=OUTPUT_; //G6
trisval.bit.pinG7=OUTPUT_; //G7
set_trisvalue();
set_tris_();
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_4);// TIMER0 8.1ms rsesolution
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
setup_vref(FALSE);
setup_low_volt_detect(FALSE);
setup_oscillator(OSC_16MHZ|OSC_PLL_ON);
EXT_INT_EDGE(0,L_TO_H);
enable_interrupts(INT_EXT);
disable_interrupts(INT_TIMER1);
disable_interrupts(GLOBAL);
loop:
spi_xfer(myspi,0xAAAA,16);
delay_ms(200);
goto loop;
I see nothing on PIN_E0, PIN_E1,PIN_E2 on my scope, any suggestion ? _________________ Dr Suleyman CANAN
R&D Electronic Engineer
https://suleymancanan.wordpress.com
Do whatever you do with amateur spirit -
But always feel professional.
Posted: Fri Nov 10, 2017 8:17 am |
| Quote: | void main(void)
set_trisvalue();
set_tris_();
Post the code for the lines shown in bold. |
scanan
Posted: Mon Nov 13, 2017 3:06 am |
| PCM programmer wrote: | | Quote: | void main(void)
set_trisvalue();
set_tris_();
the functions are added.. _________________ Dr Suleyman CANAN
But always feel professional. |
Posted: Mon Nov 13, 2017 4:10 pm |
You might not see it on your scope because you're using a slow repetition
rate in your while() loop. Try this program which has a much faster loop
speed: | Code: |
#device adc=8
spi_xfer(myspi, 0x5555, 16);
delay_us(200);
scanan
Posted: Tue Nov 14, 2017 1:41 am |
| PCM programmer wrote: | You might not see it on your scope because you're using a slow repetition
speed: |
You're right my loop was too slow,
Many Thanks, problem solved. _________________ Dr Suleyman CANAN
