		| Author | Message |
		| Guest
				| MPLAB/CCS |
				|  Posted: Fri May 30, 2008 4:07 am |   |
				| I am trying to run CCS version 4.071 from within MPLAB 8.00.
 When I try to build I get an error saying CCS compiler not installed on this machine.
 CCS is installed and works fine.
 Any ideas?
 Best regards,
		| CCS
		| Guest
				| MPLAB/CCS |
				|  Posted: Fri May 30, 2008 12:00 pm |   |
				| Thanks for the reply, but I have done what you suggest. |  |
		| PCM programmer
		| Guest
				| MPLAB/CCS |
				|  Posted: Fri May 30, 2008 1:30 pm |   |
				| Looking in Help, About I have CCS PCWH version 4.071.
 In 'project', 'select language toolsuit' I have  C:\Program Files\PICC\Pcw.exe.
 Regards
		| PCM programmer
		| Guest
				| Error : " Unknown device type    -- Try PCH" |
				|  Posted: Tue Sep 16, 2008 9:17 pm |   |
				| I am trying to run CCS version 4.038 from within MPLAB 7.50 When I compile code for pic18F2450, appear error: "Unknown device type    -- Try PCH"
 Then I replace code for pic18f452,  appear error: "Unknown device type    -- Try PCH" too.
 Can you say to me about this problem!
  	  | Code: |  	  | #include <18F2450.h>
 #fuses HS,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
 set_tris_b(0);
 output_low(PIN_B1);
 output_high(PIN_B1);
		| ckielstra
				|  Posted: Wed Sep 17, 2008 5:28 pm |   |
				| From the error message it looks like you are using the wrong compiler version.
 The CCS compiler comes in different flavours for the different PIC families:
 PCB for PIC12
 PCM for PIC16
 PCH for PIC18
 PCD for PIC24 and dsPic
 These are all command line tools. The Windows versions have similar names but with the character W added. For a complete overview see: http://www.ccsinfo.com/content.php?page=ideoverview
 If you do have the correct compiler version then your mistake was you forgot to tell MPLAB which processor you are using: in MPLAB select 'Configure / Select device ... '  and select here your processor type.
		| quocloc.pham
				| Re: Error : " Unknown device type -- Try PCH" |
				|  Posted: Wed Sep 17, 2008 7:53 pm |   |
				|  	  | ckielstra wrote: |  	  | From the error message it looks like you are using the wrong compiler version.
 PCB for PIC12
 PCM for PIC16
 PCH for PIC18
 I don't think so that! because I use CCS PCH compiler (ccsc v4.038)
 and I don't forget tell MPLAB which processor I using.
  	  | Code: |  	  | #include <18F2450.h> |
		| quocloc.pham
				| No error " Unknown device type -- Try PCH" |
				|  Posted: Wed Sep 17, 2008 9:42 pm |   |
 PCB for PIC12
 PCM for PIC16
 PCH for PIC18
 I was configure the same you said, the compiler had already done!
 Thanks a lot!!
