hansolo
| DS18S20 & DS18B20 Codes |
Posted: Fri Oct 06, 2006 6:56 pm |
I find that the codes available in this site for DS18S20 & DS18B20 is a bit messy and complicated.
Below is the simple version of the codes which works. It also take care of negative temperature.
However, due to its simplicity, this will only work with one DS1820 connected to the 1-wire bus of the PIC. This code will not work with 2 or more DS1820 sharing the same 1-wire bus.
1wire.c
// (C) copyright 2003 j.d.sandoz / jds-pic !at! losdos.dyndns.org
// released under the GNU GENERAL PUBLIC LICENSE (GPL)
// refer to http://www.gnu.org/licenses/gpl.txt
// This program is free software; you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation; either version 2 of the License, or
// (at your option) any later version.
// This program is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with this program; if not, write to the Free Software
// Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
/***********************1Wire Class***********************/
/*Description: This class handles all communication */
/* between the processor and the 1wire */
/* sensors.
/*-------1-wire definitions-------*/
#define ONE_WIRE_PIN PIN_A0
/*******************1-wire communication functions********************/
/************onewire_reset*************************************************/
/*This function initiates the 1wire bus */
/*PARAMETERS: */
/*RETURNS: */
void onewire_reset() // OK if just using a single permanently connected device
output_low(ONE_WIRE_PIN);
delay_us( 500 ); // pull 1-wire low for reset pulse
output_float(ONE_WIRE_PIN); // float 1-wire high
delay_us( 500 ); // wait-out remaining initialisation window.
/*********************** onewire_write() ********************************/
/*This function writes a byte to the sensor.*/
/*Parameters: byte - the byte to be written to the 1-wire */
/*Returns: */
void onewire_write(int data)
int count;
for (count=0; count<8; ++count)
delay_us( 2 ); // pull 1-wire low to initiate write time-slot.
output_bit(ONE_WIRE_PIN, shift_right(&data,1,0)); // set output bit on 1-wire
delay_us( 60 ); // wait until end of write slot.
output_float(ONE_WIRE_PIN); // set 1-wire high again,
delay_us( 2 ); // for more than 1us minimum.
/*********************** read1wire() *********************************/
/*This function reads the 8 -bit data via the 1-wire sensor. */
/*Parameters: */
/*Returns: 8-bit (1-byte) data from sensor */
int onewire_read()
int count, data;
delay_us( 2 ); // pull 1-wire low to initiate read time-slot.
output_float(ONE_WIRE_PIN); // now let 1-wire float high,
delay_us( 8 ); // let device state stabilise,
shift_right(&data,1,input(ONE_WIRE_PIN)); // and load result.
delay_us( 120 ); // wait until end of read slot.
return( data );
ds1820.c
float ds1820_read()
int8 busy=0, temp1, temp2;
signed int16 temp3;
float result;
onewire_reset();
onewire_write(0xCC);
onewire_write(0x44);
while (busy == 0)
busy = onewire_read();
onewire_reset();
onewire_write(0xBE);
temp1 = onewire_read();
temp2 = onewire_read();
temp3 = make16(temp2, temp1);
result = (float) temp3 / 2.0; //Calculation for DS18S20 with 0.5 deg C resolution
// result = (float) temp3 / 16.0; //Calculation for DS18B20 with 0.1 deg C resolution
delay_ms(200);
return(result);
Main code
#include <16F877A.h>
#device *=16
#device adc=8
#FUSES NOWDT, HS, PUT, NOPROTECT, NODEBUG, BROWNOUT, NOLVP, NOCPD, NOWRT
#include<1wire.c>
#include<lcd.c>
#include<ds1820.c>
float temperature;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_vref(VREF_LOW|-2);
lcd_putc("\f");
while (1)
temperature = ds1820_read();
lcd_gotoxy(1,1);
printf(lcd_putc,"TEMP: %3.1f ", temperature);
lcd_putc(223);
lcd_putc("C ");
lcd_gotoxy(1,2);
if(temperature >= 29.0)
printf(lcd_putc,"Hot! ");
else if( temperature >= 20 && temperature < 29.0)
printf(lcd_putc,"Comfort!");
printf(lcd_putc,"Cold! ");
jds-pic
| Re: DS18S20 & DS18B20 Codes |
Posted: Wed Oct 11, 2006 3:02 pm |
| hansolo wrote: | I find that the codes available in this site for DS18S20 & DS18B20 is a bit messy and complicated.
Below is the simple version of the codes which works. It also take care of negative temperature. |
the entirety of the onewire driver code is copied directly from my post of Fri Jun 04, 2004 9:54 am EST -- a post which noted that the attached code is covered under the GPL.
http://ccsinfo.com/forum/viewtopic.php?t=19520
you can read about the GPL here
jds-pic |
hansolo
Posted: Wed Oct 11, 2006 3:43 pm |
I posted the codes for sharing and I am not selling it.
I hope you do not mind.
Thanks. |
jds-pic
Posted: Sun Oct 15, 2006 1:34 pm |
| hansolo wrote: | I posted the codes for sharing and I am not selling it.
Thanks. |
you must carry forward the GPL license and as well as the copyright(s) of the original author(s).
jds-pic |
hansolo
Posted: Sun Oct 15, 2006 5:52 pm |
| jds-pic wrote: | | hansolo wrote: | I posted the codes for sharing and I am not selling it.
Thanks. |
jds-pic |
My mistake. I did not read the fine print.
I will amend it.
Sorry. |
ulaska
Posted: Mon Jul 16, 2007 3:08 pm |
i tried this codes. it works OK.
i use 2x16 standard LCD, DS1280 and pic16f876a.
but it shows the temperatures like, 25.4 , 25.9, 27.4 ,
it increases or decreases 0.5 degree.
the resolution is 0.5 degree, but it isnt whole numbers or half (25.0, 25.5 etc.)
i think there are some problems with data types in ds1820_read() ?
but i cannot see any mistake, also i tried to add 0.1 to reach whole numbers but doesnt works.
thank you.
p.s. i am new in PICs |
scanan
| 0.1 degree resolution working code |
Posted: Wed Jan 16, 2008 4:29 pm |
A working modification of hansolo - jds-pic codes.
Now it works fine.
| Code: | // onewire library, for dallas onewire devices
// currently includes:
// - generic onewire functions (init, readbyte, sendbyte, crc, etc.)
// - ds1822 dallas-semi econo-thermometer
//Previously Posted in CCS thread from jds-pic
//Revision Made By SCanan Date: 26.06.2007
#include <16f628.h>
#device *=16
// internal osilator used
#FUSES NOWDT,INTRC, NOPUT, NOPROTECT, NOBROWNOUT, NOMCLR, NOLVP, NOCPD//for 16f628
#USE RS232(BAUD=9600, XMIT=PIN_B2, RCV=PIN_B1)
#include "1wire.c"
int8 tH,tL,Conf;
float ds1820_read()
signed int16 temp3;
float result;
onewire_reset();
delay_ms(200);
while (busy == 0)
onewire_reset();
tH=onewire_read();
tL=onewire_read();
Conf=onewire_read();
//result = (float) temp3 / 2.0; // 0.5 deg C resolution
result = (float) temp3 / 16.0; //0.1 deg C resolution
delay_ms(200);
return(result);
float temperature;
//for 10 bit resolution mod
onewire_write(0x4E);
onewire_write(125);
onewire_write(-55); //this should be done for proper working of DS18B20
onewire_write(127);
onewire_reset();
onewire_write(0x48);
delay_ms(15);
while (1)
printf("Temperature= %3.1f\n\r",temperature);
////// 1wire.c fontion //////
///// DS18b20 data pin connected to pic16f628 B0 pin //////
/* sensors.
#define ONE_WIRE_PIN PIN_B0
/*Returns: */
int count;
/*Parameters: */
int onewire_read()
int count, data;
return( data );
mthornton
Joined: 22 Jan 2008 Posts: 4 Location: Canal Flats BC
Posted: Thu Feb 21, 2008 3:56 pm |
The above ds18s20 code is nice & light & works, but I avoided the floating variables by integer-multiplying the result by 5 instead of dividing by 2 or 16. So my result is in DegC x 10. No problem, makes it even lighter. Just have to remember where to place the decimal-point in the display routine.
instead of the lines:
float ds1820_read()
float result
used :
signed int16 ds1820_read()
signed int16 result
result = temp3 * 5; |
40inD
Joined: 30 Jul 2007 Posts: 112 Location: Moscow, Russia
Posted: Sat Apr 26, 2008 1:08 pm |
Why i get 0.5 degree resolution in 18B20 when i do this:
| Code: | | result = (float) temp3 / 16.0; |
meereck
Posted: Tue Apr 29, 2008 4:42 am |
hello, thanx for the source code. Works like a charm with both DS18S20 and B. Can any1 tell me what the maximal length of a cable between a PIC and the sensor can be?
cheers meereck |
noobprogrammer
| ds18s20 |
Posted: Tue May 20, 2008 7:07 pm |
| meereck wrote: | hello, thanx for the source code. Works like a charm with both DS18S20 and B. Can any1 tell me what the maximal length of a cable between a PIC and the sensor can be?
cheers meereck |
anybody has the schematic for this? thanks |
muerte
| Re: ds18s20 |
Posted: Wed May 21, 2008 3:40 am |
Hi all,
| noobprogrammer wrote: | | meereck wrote: | hello, thanx for the source code. Works like a charm with both DS18S20 and B. Can any1 tell me what the maximal length of a cable between a PIC and the sensor can be?
cheers meereck |
Schematic?
Look this:
connect DS18S20 to this pin (or another defined)
and DS18S20 data sheet from Maxim http://datasheets.maxim-ic.com/en/ds/DS18S20.pdf _________________ Best regards,
muerte |
meereck
| Re: ds18s20 |
Posted: Wed May 21, 2008 7:08 am |
| muerte wrote: | Hi all,
cheers meereck |
Schematic?
Look this:
and DS18S20 data sheet from Maxim http://datasheets.maxim-ic.com/en/ds/DS18S20.pdf |
In addition, do not forget the pull-up resistor on the data line |
noobprogrammer
| Re: ds18s20 |
Posted: Wed May 21, 2008 7:35 pm |
cheers meereck |
Schematic?
Look this:
will this work for the pic18f452? and which ports and pins are connected to the LCD..sorrie im a noob..thanks for your help! |
