DS1820 maximum distance
PostPosted: Fri May 02, 2008 5:45 am     Reply with quote
I want to connect a maximum of 50 DS1820 devices to a pic18f452. I have gotten my code to work - no problem. However when I increased my cable length to 100m, it stopped working.
Please can someone tell me how to connect the DS1820 so it can work over distances greater 100m. I think I am looking for a maximum of 500m..
ckielstra
PostPosted: Fri May 02, 2008 7:09 am     Reply with quote
Check the list of Maxim 1-wire application notes.
Especially these application notes will be of great help:
APPLICATION NOTE 148: Guidelines for Reliable 1-Wire Networks
APPLICATION NOTE 244: Advanced 1-Wire Network Driver
APPLICATION NOTE 3829: Determining the Recovery Time for Multiple-Slave 1-Wire Networks
With careful design, good cable quality, impedance matching, reduced speed, etc. it should be possible to achieve 500m.
Cihan
Re: DS1820 maximum distance
PostPosted: Fri Aug 01, 2008 3:39 am     Reply with quote
How can u select the devices to read? for example i have 4 ds1820 in one wire but i can't read the temperature for each one? can u help me?
herselmann
PostPosted: Fri Aug 01, 2008 3:53 am     Reply with quote
See app note AN187 1-Wire Search Algorithm. Once you have found all your devices, you can use the MATCH ROM command to address a specific device on the network. See a similar post recently in this forum for more clues.
There are only 10 kinds of people, those who understand binary and those who don't.
