tophe59
Posted: Tue Oct 25, 2005 4:57 am |
I have made simplify code. But same problem Heeelp meeee
| Code: | #include "18F4620.h"
#use delay (clock=10000000)
#fuses HS,NOWDT,NOPROTECT,NOLVP// ,H4
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
// a faire:
// animer du texte
//***definition des E/S Divers ***
#define pwm1 pin_c1 // psx -> moteur 1
#define pwm2 pin_c2 // psx -> moteur 2
//**** definition des commande******
//******Déclaration des variables globales *********
int i,j,secondes,adc_preced;
int tps_servo,servo[8];
int image_n,menu_choix;
int duty1;
int xdraw,ydraw; //position X Y pour drawblaise
long intertim;
//***************** timer 1 **********************
#int_timer1
void timer1()
{// 5< servo <23
SET_TIMER1(0xfe0b+get_timer1()); //inter toutes les 200us (ck timer 0.2us)
//***************** main **********************
set_tris_c(0x11);//port c 0=en sortie set_tris_c(0x00);//sortie
set_tris_d(0x00);
set_tris_b(0x00);
set_tris_a(0x00);//sortie
// set_tris_a(0xff);//entrée
set_tris_e(0x00);//sortie
setup_timer_1 (T1_INTERNAL|T1_DIV_BY_8); //init timer
enable_interrupts(global);
for(;;){delay_us(10);}
| Code: | Filename: test_timer.LST
ROM used: 246 bytes (0%)
Largest free fragment is 65286
RAM used: 44 (1%) at main() level
46 (1%) worst case
Stack: 1 worst case (0 in main + 1 for interrupts)
0000: GOTO 00C0
0008: MOVFF FE8,05
000C: MOVFF FD8,06
0010: MOVFF FE0,07
0014: MOVLB 0
0016: MOVFF FE9,0D
001A: MOVFF FEA,08
001E: MOVFF FE1,09
0022: MOVFF FE2,0A
0026: MOVFF FD9,0B
002A: MOVFF FDA,0C
002E: MOVFF FF3,14
0032: MOVFF FF4,15
0036: MOVFF FFA,16
003A: MOVFF 00,0F
003E: MOVFF 01,10
0042: MOVFF 02,11
0046: MOVFF 03,12
004A: MOVFF 04,13
004E: BTFSS F9D.0
0050: GOTO 005A
0054: BTFSC F9E.0
0056: GOTO 00A0
005A: MOVFF 0F,00
005E: MOVFF 10,01
0062: MOVFF 11,02
0066: MOVFF 12,03
006A: MOVFF 13,04
006E: MOVFF 0D,FE9
0072: MOVFF 08,FEA
0076: MOVFF 09,FE1
007A: MOVFF 0A,FE2
007E: MOVFF 0B,FD9
0082: MOVFF 0C,FDA
0086: MOVFF 14,FF3
008A: MOVFF 15,FF4
008E: MOVFF 16,FFA
0092: MOVFF 05,FE8
0096: MOVFF 07,FE0
009A: MOVFF 06,FD8
009E: RETFIE 0
.................... #include "18F4620.h"
.................... //////// Standard Header file for the PIC18F4620 device ////////////////
.................... #device PIC18F4620
.................... #list
.................... #use delay (clock=10000000)
.................... #fuses HS,NOWDT,NOPROTECT,NOLVP// ,H4
.................... #use fast_io(A)
.................... #use fast_io(B)
.................... #use fast_io(C)
.................... #use fast_io(D)
.................... #use fast_io(E)
.................... // a faire:
.................... // animer du texte
.................... //***definition des E/S Divers ***
.................... #define pwm1 pin_c1 // psx -> moteur 1
.................... #define pwm2 pin_c2 // psx -> moteur 2
.................... //**** definition des commande******
.................... //******Déclaration des variables globales *********
.................... int i,j,secondes,adc_preced;
.................... int tps_servo,servo[8];
.................... int image_n,menu_choix;
.................... int duty1;
.................... int xdraw,ydraw; //position X Y pour drawblaise
.................... long intertim;
.................... //***************** timer 1 **********************
.................... #int_timer1
.................... void timer1()
.................... {// 5< servo <23
.................... SET_TIMER1(0xfe0b+get_timer1()); //inter toutes les 200us (ck timer 0.2us)
00A0: MOVF FCE,W
00A2: MOVFF FCF,03
00A6: ADDLW 0B
00A8: MOVWF 2C
00AA: MOVLW FE
00AC: ADDWFC 03,W
00AE: MOVWF 2D
00B0: MOVFF 2D,FCF
00B4: MOVFF 2C,FCE
.................... tps_servo++;
00B8: INCF 1C,F
.................... // Prog principal
00BA: BCF F9E.0
00BC: GOTO 005A
.................... void main(void)
00C0: CLRF FF8
00C2: BCF FD0.7
00C4: BSF 0D.7
00C6: CLRF FEA
00C8: CLRF FE9
00CA: MOVF FC1,W
00CC: ANDLW C0
00CE: IORLW 0F
00D0: MOVWF FC1
00D2: MOVLW 07
00D4: MOVWF FB4
.................... set_tris_c(0x11);//port c 0=en sortie set_tris_c(0x00);//sortie
00D6: MOVLW 11
00D8: MOVWF F94
.................... set_tris_d(0x00);
00DA: MOVLW 00
00DC: MOVWF F95
.................... set_tris_b(0x00);
00DE: MOVWF F93
.................... set_tris_a(0x00);//sortie
00E0: MOVWF F92
.................... // set_tris_a(0xff);//entrée
.................... set_tris_e(0x00);//sortie
00E2: MOVWF F96
.................... setup_timer_1 (T1_INTERNAL|T1_DIV_BY_8); //init timer
00E4: MOVLW B5
00E6: MOVWF FCD
.................... enable_interrupts(INT_TIMER1);
00E8: BSF F9D.0
.................... enable_interrupts(global);
00EA: MOVLW C0
00EC: IORWF FF2,F
.................... for(;;){delay_us(10);}
00EE: MOVLW 08
00F0: MOVWF 00
00F2: DECFSZ 00,F
00F4: BRA 00F2
00F6: BRA 00EE
00F8: SLEEP
Configuration Fuses:
Word 1: 0200 HS NOIESO NOFCMEN RESERVED
Word 2: 1E1F BROWNOUT NOWDT BORV21 NOPUT WDT32768
Word 3: 8300 CCP2C1 PBADEN NOLPT1OSC MCLR RESERVED
Word 4: 0081 STVREN NODEBUG NOLVP NOXINST RESERVED
Word 5: C00F NOPROTECT NOCPD NOCPB
Word 6: E00F NOWRT NOWRTD NOWRTC NOWRTB
Word 7: 400F NOEBTR NOEBTRB |
tophe59
Posted: Tue Oct 25, 2005 4:59 am |
i bugging
tophe59
Posted: Tue Oct 25, 2005 5:00 am |
i bugging
tophe59
i bugging
tophe59
Posted: Tue Oct 25, 2005 5:01 am |
i bugging
tophe59
Posted: Tue Oct 25, 2005 5:02 am |
i bugging
tophe59
Posted: Tue Oct 25, 2005 5:36 am |
I have some problem's with my "reply"
If a moderator can clean this. Thank's |
asmallri
Joined: 12 Aug 2004 Posts: 1679 Location: Perth, Australia
Posted: Tue Oct 25, 2005 6:14 am |
| tophe59 wrote: | I have some problem's with my "reply"
You can clean it yourself (provided you are logged in). When you visit a thread that you have already posted on you will note an X in the top bar of the message window. This will delete your post. _________________ Regards, Andrew
Mark
Posted: Tue Oct 25, 2005 6:44 am |
Quite often when you post a thread that contains a large amount of text, you will get an error. The post however still works. If you go back and check after 30-60 seconds you will see it and then you won't keep posting. You can delete a post if is the last post in the thread. Otherwise, you can edit the post and remove all the text. |
Mark
Posted: Tue Oct 25, 2005 6:57 am |
If you are using the debugger, shouldn't you have
in your code?
The debug pins are on port b. It seems to me that
will make the debug pins outputs and cause the debugger to crash (stop) working. I would comment out this line and see what happens. |
tophe59
Posted: Tue Oct 25, 2005 10:09 am |
Ok i'm just testing the code with a 16f877 and no problem.
I am lost  |
tophe59
Posted: Wed Oct 26, 2005 2:09 am |
Now that work
I think the firmware of my ICD2 was in question. The fact to change 18F to 16F anf 18F again do now it work.
Thank's all for your help !  |
