enabling timer interrupt cause reset
Goto page Previous  1, 2
tophe59
PostPosted: Tue Oct 25, 2005 4:57 am     Reply with quote
I have made simplify code. But same problem Crying or Very sad Heeelp meeee Crying or Very sad
#include "18F4620.h"
#use delay (clock=10000000)
#fuses HS,NOWDT,NOPROTECT,NOLVP// ,H4
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
// a faire:
// animer du texte
//***definition des E/S Divers  ***
#define pwm1   pin_c1   //         psx -> moteur 1
#define pwm2   pin_c2   //          psx -> moteur 2
//**** definition des commande******
//******Déclaration des variables globales *********
   int    i,j,secondes,adc_preced;
   int      tps_servo,servo[8];
   int    image_n,menu_choix;
   int      duty1;
   int    xdraw,ydraw; //position X Y pour drawblaise
   long   intertim;
//***************** timer 1 **********************
#int_timer1
   void timer1()
   {//      5< servo <23
   SET_TIMER1(0xfe0b+get_timer1()); //inter toutes les 200us (ck timer 0.2us)
//***************** main **********************
   set_tris_c(0x11);//port c 0=en sortie      set_tris_c(0x00);//sortie
   set_tris_d(0x00);
   set_tris_b(0x00);
   set_tris_a(0x00);//sortie
//   set_tris_a(0xff);//entrée
   set_tris_e(0x00);//sortie
   setup_timer_1 (T1_INTERNAL|T1_DIV_BY_8); //init timer
   enable_interrupts(global);
   for(;;){delay_us(10);}
         Filename: test_timer.LST
               ROM used: 246 bytes (0%)
                         Largest free fragment is 65286
               RAM used: 44 (1%) at main() level
                         46 (1%) worst case
               Stack:    1 worst case (0 in main + 1 for interrupts)
0000:  GOTO   00C0
0008:  MOVFF  FE8,05
000C:  MOVFF  FD8,06
0010:  MOVFF  FE0,07
0014:  MOVLB  0
0016:  MOVFF  FE9,0D
001A:  MOVFF  FEA,08
001E:  MOVFF  FE1,09
0022:  MOVFF  FE2,0A
0026:  MOVFF  FD9,0B
002A:  MOVFF  FDA,0C
002E:  MOVFF  FF3,14
0032:  MOVFF  FF4,15
0036:  MOVFF  FFA,16
003A:  MOVFF  00,0F
003E:  MOVFF  01,10
0042:  MOVFF  02,11
0046:  MOVFF  03,12
004A:  MOVFF  04,13
004E:  BTFSS  F9D.0
0050:  GOTO   005A
0054:  BTFSC  F9E.0
0056:  GOTO   00A0
005A:  MOVFF  0F,00
005E:  MOVFF  10,01
0062:  MOVFF  11,02
0066:  MOVFF  12,03
006A:  MOVFF  13,04
006E:  MOVFF  0D,FE9
0072:  MOVFF  08,FEA
0076:  MOVFF  09,FE1
007A:  MOVFF  0A,FE2
007E:  MOVFF  0B,FD9
0082:  MOVFF  0C,FDA
0086:  MOVFF  14,FF3
008A:  MOVFF  15,FF4
008E:  MOVFF  16,FFA
0092:  MOVFF  05,FE8
0096:  MOVFF  07,FE0
009A:  MOVFF  06,FD8
009E:  RETFIE 0
....................  #include "18F4620.h"
....................  //////// Standard Header file for the PIC18F4620 device ////////////////
.................... #device PIC18F4620
.................... #list
.................... #use delay (clock=10000000)
.................... #fuses HS,NOWDT,NOPROTECT,NOLVP// ,H4
.................... #use fast_io(A)
.................... #use fast_io(B)
.................... #use fast_io(C)
.................... #use fast_io(D)
.................... #use fast_io(E)
.................... // a faire:
.................... // animer du texte
.................... //***definition des E/S Divers  ***
.................... #define pwm1   pin_c1   //         psx -> moteur 1
.................... #define pwm2   pin_c2   //          psx -> moteur 2
.................... //**** definition des commande******
.................... //******Déclaration des variables globales *********
....................    int    i,j,secondes,adc_preced;
....................    int      tps_servo,servo[8];
....................    int    image_n,menu_choix;
....................    int      duty1;
....................    int    xdraw,ydraw; //position X Y pour drawblaise
....................    long   intertim;
.................... //***************** timer 1 **********************
.................... #int_timer1
....................    void timer1()
....................    {//      5< servo <23
....................    SET_TIMER1(0xfe0b+get_timer1()); //inter toutes les 200us (ck timer 0.2us)
00A0:  MOVF   FCE,W
00A2:  MOVFF  FCF,03
00A6:  ADDLW  0B
00A8:  MOVWF  2C
00AA:  MOVLW  FE
00AC:  ADDWFC 03,W
00AE:  MOVWF  2D
00B0:  MOVFF  2D,FCF
00B4:  MOVFF  2C,FCE
....................    tps_servo++;
00B8:  INCF   1C,F
.................... //                   Prog principal
00BA:  BCF    F9E.0
00BC:  GOTO   005A
....................    void main(void)
00C0:  CLRF   FF8
00C2:  BCF    FD0.7
00C4:  BSF    0D.7
00C6:  CLRF   FEA
00C8:  CLRF   FE9
00CA:  MOVF   FC1,W
00CC:  ANDLW  C0
00CE:  IORLW  0F
00D0:  MOVWF  FC1
00D2:  MOVLW  07
00D4:  MOVWF  FB4
....................    set_tris_c(0x11);//port c 0=en sortie      set_tris_c(0x00);//sortie
00D6:  MOVLW  11
00D8:  MOVWF  F94
....................    set_tris_d(0x00);
00DA:  MOVLW  00
00DC:  MOVWF  F95
....................    set_tris_b(0x00);
00DE:  MOVWF  F93
....................    set_tris_a(0x00);//sortie
00E0:  MOVWF  F92
.................... //   set_tris_a(0xff);//entrée
....................    set_tris_e(0x00);//sortie
00E2:  MOVWF  F96
....................    setup_timer_1 (T1_INTERNAL|T1_DIV_BY_8); //init timer
00E4:  MOVLW  B5
00E6:  MOVWF  FCD
....................    enable_interrupts(INT_TIMER1);
00E8:  BSF    F9D.0
....................    enable_interrupts(global);
00EA:  MOVLW  C0
00EC:  IORWF  FF2,F
....................    for(;;){delay_us(10);}
00EE:  MOVLW  08
00F0:  MOVWF  00
00F2:  DECFSZ 00,F
00F4:  BRA    00F2
00F6:  BRA    00EE
00F8:  SLEEP
Configuration Fuses:
   Word  1: 0200   HS NOIESO NOFCMEN RESERVED
   Word  2: 1E1F   BROWNOUT NOWDT BORV21 NOPUT WDT32768
   Word  3: 8300   CCP2C1 PBADEN NOLPT1OSC MCLR RESERVED
   Word  4: 0081   STVREN NODEBUG NOLVP NOXINST RESERVED
   Word  5: C00F   NOPROTECT NOCPD NOCPB
   Word  6: E00F   NOWRT NOWRTD NOWRTC NOWRTB
   Word  7: 400F   NOEBTR NOEBTRB
tophe59
PostPosted: Tue Oct 25, 2005 4:59 am     Reply with quote
i bugging
tophe59
PostPosted: Tue Oct 25, 2005 5:00 am     Reply with quote
i bugging
tophe59
i bugging
tophe59
PostPosted: Tue Oct 25, 2005 5:01 am     Reply with quote
i bugging
tophe59
PostPosted: Tue Oct 25, 2005 5:02 am     Reply with quote
i bugging
tophe59
PostPosted: Tue Oct 25, 2005 5:36 am     Reply with quote
I have some problem's with my "reply" Laughing
If a moderator can clean this. Thank's
asmallri
PostPosted: Tue Oct 25, 2005 6:14 am     Reply with quote
You can clean it yourself (provided you are logged in). When you visit a thread that you have already posted on you will note an X in the top bar of the message window. This will delete your post.
Regards, Andrew
Mark
PostPosted: Tue Oct 25, 2005 6:44 am     Reply with quote
Quite often when you post a thread that contains a large amount of text, you will get an error. The post however still works. If you go back and check after 30-60 seconds you will see it and then you won't keep posting. You can delete a post if is the last post in the thread. Otherwise, you can edit the post and remove all the text.
Mark
PostPosted: Tue Oct 25, 2005 6:57 am     Reply with quote
If you are using the debugger, shouldn't you have
#device ICD=TRUE
in your code?
The debug pins are on port b. It seems to me that
set_tris_b(0x00);
will make the debug pins outputs and cause the debugger to crash (stop) working. I would comment out this line and see what happens.
tophe59
PostPosted: Tue Oct 25, 2005 10:09 am     Reply with quote
Ok i'm just testing the code with a 16f877 and no problem.
I am lost Confused
tophe59
PostPosted: Wed Oct 26, 2005 2:09 am     Reply with quote
Now that work Shocked
I think the firmware of my ICD2 was in question. The fact to change 18F to 16F anf 18F again do now it work.
Thank's all for your help ! Wink
Page 2 of 2
