Dumb question on Unions
bkamen
PostPosted: Sun Feb 06, 2005 7:35 pm     Reply with quote
This may seem pretty remedial... but I've never used unions before...
struct portd_pin_map {
   int LED;            // LED's 1-8
        } portd ;
#byte    portd = 8            // Port C
struct portd_pin_map const PORTD_SET = {0};
struct porte_pin_map {
   int LED:2;            // LED's 9-10
   boolean BAT_LED;      // Center LED11
        } porte ;
#byte    porte = 9            // Port C
struct porte_pin_map const PORTE_SET = {0,0};
union led_map {
   int portd.led,
   int porte.led
   } led_display;
I don't have that right since I get a compile error (expecting a ; or , -- on the first line inside the union)... so I thought I would ask.
Thanks in advance,
-Ben
Mark
PostPosted: Sun Feb 06, 2005 9:16 pm     Reply with quote
Not sure what you are trying to do
        } portd ;
        } porte ;
union led_map {
   int somevar1;
   int somevar2;
   } led_display;
but that's how to declare a union. Do you know what a union is? From your code I think you probably were trying to do this
        } portd ;
        } porte ;
union led_map {
   struct portd_pin_map portd;
   struct porte_pin_map porte;
   } led_display;
But that doesn't really make since either since you location where portd and porte are. Basically the above union is an 8 bit variable that can be accessed by different members but won't have anything to do with portd or porte. What exactly are you trying to do?
bkamen
PostPosted: Sun Feb 06, 2005 9:25 pm     Reply with quote
I have 10 LED's (8 on port-D and 2 on port-E) of which I want to assign as a single INT16 so when I set them according to their 10bit value, I can just assign...
The 11th LED is for something else - thus I'd like to make it it's own element.
From what I've read online, I think I'm on the wrong track with Union...
MAKE8(); will be fine too.
Charlie U
PostPosted: Sun Feb 06, 2005 10:35 pm     Reply with quote
Actually, you may be on the right track with the unions. Here's some code that I whipped up and compiled with 3.212 for the 18F452 and it looks like it might do what you want. First the header file:
#include <18F452.h>
#device adc=8
#fuses NOWDT,WDT128,HS, NOPROTECT, NOOSCSEN, NOBROWNOUT, BORV20, PUT, \
      NOSTVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, \
      NOCPB, NOEBTR, NOEBTRB
#byte port_a = 0x0F80
#byte port_b = 0x0F81
#byte port_c = 0x0F82
#byte port_d = 0x0F83
#byte port_e = 0x0F84
#bit LED8 = port_e.0
#bit LED9 = port_e.1
struct LED_struct
   int port_d   : 8;
   int LED8     : 1;
   int LED9     : 1;
   int filler   : 6;
union
   struct LED_struct LEDs;
   long int long_led_data;
}LED_union;
#byte LED_union = 0xF83
Now the main file:
#include "C:\Cfiles\Tests\union1\union1.h"
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   LED_union.long_led_data = 0x0555;
   LED_union.LEDs = 0x02AA;
   LED_union.LEDs.LED8 = 1;
Now here's the listing of the important bits where we manipulate the union:
....................    LED_union.long_led_data = 0x0555;
0046:  MOVLW  05
0048:  MOVWF  F84
004A:  MOVLW  55
004C:  MOVWF  F83
....................    LED_union.LEDs = 0x02AA;
004E:  MOVLW  02
0050:  MOVWF  F84
0052:  MOVLW  AA
0054:  MOVWF  F83
....................    LED_union.LEDs.LED8 = 1;
0056:  BSF    F84.0
It looks like it might be doing what you want. Note the setting of a bit by accessing it with the union.
Let us know if this is what you are looking for.
Charlie
bkamen
PostPosted: Mon Feb 07, 2005 12:11 am     Reply with quote
code removed for redundancy
Charlie
Actually, that is along the lines of what I'm doing... Thanks... the usage is a lot clearer to me now.
I'm using a 16F877. Quite frankly between union{} and make8(), I really don't mind which as long as I can do it quickly.
Thanks for the help everyone,
-Ben
