bkamen
| Dumb question on Unions |
Posted: Sun Feb 06, 2005 7:35 pm |
This may seem pretty remedial... but I've never used unions before...
| Code: | struct portd_pin_map {
int LED; // LED's 1-8
} portd ;
#byte portd = 8 // Port C
struct portd_pin_map const PORTD_SET = {0};
struct porte_pin_map {
int LED:2; // LED's 9-10
boolean BAT_LED; // Center LED11
} porte ;
#byte porte = 9 // Port C
struct porte_pin_map const PORTE_SET = {0,0};
union led_map {
int portd.led,
int porte.led
} led_display;
I don't have that right since I get a compile error (expecting a ; or , -- on the first line inside the union)... so I thought I would ask.
Thanks in advance,
-Ben |
Mark
Posted: Sun Feb 06, 2005 9:16 pm |
Not sure what you are trying to do
} portd ;
} porte ;
union led_map {
int somevar1;
int somevar2;
} led_display;
but that's how to declare a union. Do you know what a union is? From your code I think you probably were trying to do this
} portd ;
} porte ;
union led_map {
struct portd_pin_map portd;
struct porte_pin_map porte;
} led_display;
But that doesn't really make since either since you location where portd and porte are. Basically the above union is an 8 bit variable that can be accessed by different members but won't have anything to do with portd or porte. What exactly are you trying to do? |
bkamen
Posted: Sun Feb 06, 2005 9:25 pm |
I have 10 LED's (8 on port-D and 2 on port-E) of which I want to assign as a single INT16 so when I set them according to their 10bit value, I can just assign...
The 11th LED is for something else - thus I'd like to make it it's own element.
From what I've read online, I think I'm on the wrong track with Union...
MAKE8(); will be fine too. |
Charlie U
Joined: 09 Sep 2003 Posts: 183 Location: Somewhere under water in the Great Lakes
Posted: Sun Feb 06, 2005 10:35 pm |
Actually, you may be on the right track with the unions. Here's some code that I whipped up and compiled with 3.212 for the 18F452 and it looks like it might do what you want. First the header file:
#include <18F452.h>
#device adc=8
#fuses NOWDT,WDT128,HS, NOPROTECT, NOOSCSEN, NOBROWNOUT, BORV20, PUT, \
NOSTVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, \
NOCPB, NOEBTR, NOEBTRB
#byte port_a = 0x0F80
#byte port_b = 0x0F81
#byte port_c = 0x0F82
#byte port_d = 0x0F83
#byte port_e = 0x0F84
#bit LED8 = port_e.0
#bit LED9 = port_e.1
struct LED_struct
int port_d : 8;
int LED8 : 1;
int LED9 : 1;
int filler : 6;
union
struct LED_struct LEDs;
long int long_led_data;
}LED_union;
#byte LED_union = 0xF83
Now the main file:
#include "C:\Cfiles\Tests\union1\union1.h"
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
LED_union.long_led_data = 0x0555;
LED_union.LEDs = 0x02AA;
LED_union.LEDs.LED8 = 1;
Now here's the listing of the important bits where we manipulate the union:
.................... LED_union.long_led_data = 0x0555;
0046: MOVLW 05
0048: MOVWF F84
004A: MOVLW 55
004C: MOVWF F83
.................... LED_union.LEDs = 0x02AA;
004E: MOVLW 02
0050: MOVWF F84
0052: MOVLW AA
0054: MOVWF F83
.................... LED_union.LEDs.LED8 = 1;
0056: BSF F84.0
It looks like it might be doing what you want. Note the setting of a bit by accessing it with the union.
Let us know if this is what you are looking for.
Charlie |
bkamen
Posted: Mon Feb 07, 2005 12:11 am |
| Charlie U wrote: | Actually, you may be on the right track with the unions. Here's some code that I whipped up and compiled with 3.212 for the 18F452 and it looks like it might do what you want. First the header file:
code removed for redundancy
Charlie |
Actually, that is along the lines of what I'm doing... Thanks... the usage is a lot clearer to me now.
I'm using a 16F877. Quite frankly between union{} and make8(), I really don't mind which as long as I can do it quickly.
Thanks for the help everyone,
-Ben |
