lahoras Guest
| ICD-1 |
Posted: Sat Dec 18, 2004 7:27 pm |
Hello, I've been upgraded my ICD-1 from MicroChip to CCS and works fine, but this is running at 3,6864 mhz, I want to Know how I can do to Ugrade it to 20 Mhz, so the bootloader included by CCS only work with 3,68 Mhz only if, I replace xtal by 20 Mhz, CCS ICD program can't conect with it, can anybody help me?
best regards
Ariel |
Posted: Fri Feb 25, 2005 5:56 pm |
| you have to install the 20 mhz software before you replace the crystal. or use a another programmer and install the hex file you can get it from ccs |
pikman
Posted: Mon Mar 07, 2005 4:54 pm |
OK, but CCS ICD control program detects that my xtal is 3,68 for any reason and don't give me donwload other software, I have dicovered the problem, and this is due becouse CCS include a file called bootload.hex, this is used to upgrade to CCS , MicroChip ICD-1, that originally it works only at 3,68 Mhz, then I think dissasembly bootloader and I will edit on setup program the file 0x99 (SPBRG) to change for 20 Mhz, my porblem is that I don't know if the circuit of the ICD-S20 of CCS is similar to the MicroChip 's ICD-1, but it is worthwhile test it.
great.
ARIEL |
