19.6608MHz instead of 20MHz
Will Reeve
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Mon Aug 23, 2004 9:01 am     Reply with quote
I am limited for space (physical) and a perfect size crystal is available at 19.6608MHz. It's a USB project using the USBN9603 (which is using it's own 24MHz crystal).
I was wondering how good the CCS compiler is at working out it's delay_us etc, if I set the delay(clock=19660800)? I can't see any other issues for not running at 20MHz as I wanted?
Keep well,
Will
SherpaDoug
PostPosted: Mon Aug 23, 2004 9:31 am     Reply with quote
CCS works very well with odd clock frequencies. I use all sorts of clock frequencies to make frequency divisions easy.
Another frequency you may want to use
PostPosted: Mon Aug 23, 2004 10:15 am     Reply with quote
I use 18.432 in many of my designs as an exact multiple for accurate (0% error) baudrates.
Darren Rook
PostPosted: Mon Aug 23, 2004 10:38 am     Reply with quote
I thought the golden rule was if you sum up all the numbers and then divide equally by three, you have 0% error for baud rates.
PostPosted: Fri Sep 24, 2004 10:45 pm     Reply with quote
i just wanted to point out the digits in 18.432 add up to 18, which is evenly divisible by 3 (18%3 = 0). So you just answered your own question. (I have no idea if that golden rule is true or not, just doing some arithmetic).
