Will Reeve
Joined: 30 Oct 2003 Posts: 209 Location: Norfolk, England
| 19.6608MHz instead of 20MHz |
Posted: Mon Aug 23, 2004 9:01 am |
I am limited for space (physical) and a perfect size crystal is available at 19.6608MHz. It's a USB project using the USBN9603 (which is using it's own 24MHz crystal).
I was wondering how good the CCS compiler is at working out it's delay_us etc, if I set the delay(clock=19660800)? I can't see any other issues for not running at 20MHz as I wanted?
Keep well,
Will |
SherpaDoug
Posted: Mon Aug 23, 2004 9:31 am |
CCS works very well with odd clock frequencies. I use all sorts of clock frequencies to make frequency divisions easy. _________________ The search for better is endless. Instead simply find very good and get the job done. |
dyeatman
| Another frequency you may want to use |
Posted: Mon Aug 23, 2004 10:15 am |
| I use 18.432 in many of my designs as an exact multiple for accurate (0% error) baudrates. |
Darren Rook
Joined: 06 Sep 2003 Posts: 287 Location: Milwaukee, WI
Posted: Mon Aug 23, 2004 10:38 am |
| I thought the golden rule was if you sum up all the numbers and then divide equally by three, you have 0% error for baud rates. |
Posted: Fri Sep 24, 2004 10:45 pm |
| i just wanted to point out the digits in 18.432 add up to 18, which is evenly divisible by 3 (18%3 = 0). So you just answered your own question. (I have no idea if that golden rule is true or not, just doing some arithmetic). |
