valemike Guest
| Virus in the compiler updates? |
Posted: Fri Sep 03, 2004 3:02 pm |
Twice it's happened to me already:
File Name: GLH2005.TMP
Detected As: Generic Backdoor.d
Either CCS's computers are infected, or they are doing something they shouldn't be doing. |
| not found |
Posted: Fri Sep 03, 2004 8:00 pm |
Scanned all CCS stuff... and no virus found.
Could be your computer is infected and you think it's coming from CCS ! |
valemike Guest
Posted: Sat Sep 04, 2004 9:02 am |
It's a company computer, and the IT guy gives us updates like 3 times a week.
I get this problem after unzipping the update and trying to install it. Might be that the antivirus software is way too sensitive and is unnecessarily giving me false alarms.
Anyways, it is the file i mention above that causes the problem. |
Mark
Posted: Sun Sep 05, 2004 6:25 pm |
| Some of those look for signatures in files which does not always mean there is a virus. |
Guest Guest
| Anti virus software |
Posted: Tue Sep 07, 2004 1:04 am |
I've just come accross this problem.
Company IT department maintained Anti-Virus software from McAfee Associates gives a FALSE POSITIVE on file ~GLH0005.TMP when installing, and on ccscoff.exe after installation. A direct scan of the compiler update file does not find a problem.
This is since the last antivirus DAT file update.
Tried installing CCS updates all the way back to 3.205 - the antivirus now finds a virus in all these updates where previously (before the antivirus was updated) they installed ok. |
dcomer
Joined: 09 Mar 2004 Posts: 6 Location: Albuquerque, NM
| Virus |
Posted: Sun Sep 12, 2004 3:14 pm |
I'm getting the same Virus detected. McAfee Virus Scan Enterprise 7.1.0, DAT files 4390. No history of virus infections (until now) and religiously updated.
| Re: Virus |
Posted: Mon Sep 13, 2004 2:14 am |
| dcomer wrote: | | I'm getting the same Virus detected. McAffee Virus Scan Enterprise 7.1.0, DAT files 4390. No history of virus infections (until now) and religiously updated. |
What this means as another has posted, is that a pattern of bytes in the update, happens to give the same result for the algorithm used by the vrus checker, as a new virus that has come along. This is an ever more common event, as the number of 'signatures' rise. The answer is to contact McCafee, and report to them, that you are seeing what you believe is a false positive. What they then do, is 'shift' the search pattern slightly. If their search looks for a 16byte block (a common size), and currently it is looking for the first sixteen bytes of this virus, they move it to search for the next sixteen bytes, and change the entry in the DAT files. I have had to do this twice in the last five years, for packages that gave this type of report (one a large graphics program, and the other a Microsoft update...). In both cases, the packages tested 'clean' with two other virus checkers, and were on original CD's, so the chances of an infection were really small, making the suspicion that it was a 'false positive', easy to reach. In one case, McAfee reported the positive, while Norton, and AVG reported nothing, while in the other Norton reported the positive, while McAfee and AVG did not. This reflects the slightly different algorithms used in the packages to identify the virus.
You need to tell them which virus is reported.
If the modified DAT file does not identify the virus, you can feel happy again, while if it does, you can start to worry...
When this happened to me before, the updated DAT file was sent within 24hours.
dcomer
Posted: Mon Sep 13, 2004 5:20 pm |
Ttelmah,
Thanks for your reply. I read the reference to the previous reply, had a prior understanding of what the issues was, and was simply confirming the report as an FYI to CCS and others. I think it would be in CCS's interest to contact McCafee (sic) instead of expecting a flood of user complaints to McAfee. Although the term "flood" is debatable, solving the issue at the source is not. This, IMHO, is the difference between a customer oriented company and a company that just releases software. |
Guest Guest
| Ongoing Virus Problem |
Posted: Tue Sep 14, 2004 1:26 am |
Raised this with both CCS and McAfee at the beginning of September, when McAfee released DAT file 4.0.4388.
So far only CCS have responded to say that they have contacted McAfee to try and resolve this issue.
We are now up to DAT file 4.0.4390 - haven't had any response yet from McAfee and the problem is still persisting. |
valemike Guest
Posted: Tue Sep 14, 2004 6:39 am |
So if my antivirus program identifies it as a false positive, and takes its actions to get rid of it (whether it be to quarantine or simply delete it), does it have any effect on my compiler's installation?
-Mike |
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Tue Sep 14, 2004 5:27 pm |
| It depends on the file, but it probably will. All the files are there for a reason. |
