ICEPIC & CCS
berler_d
ICEPIC & CCS
PostPosted: Wed Jun 16, 2004 6:59 am     Reply with quote
Hi All,
Does CCS supports the ICEPIC ?
I tested the .cod of the latest version and found that it dosent work.
(In the past it worked)
What can be done about it ?
Neutone
PostPosted: Wed Jun 16, 2004 8:21 am     Reply with quote
Did you try both versions of the .cod that are supported?
PostPosted: Wed Jun 16, 2004 8:51 am     Reply with quote
Yes, I tryed both and it didnt work.
(In the past the .cod worked fine with ICEPIC)
Do you have any Idia how to solve this problem ..
Neutone
PostPosted: Wed Jun 16, 2004 8:58 am     Reply with quote
Do you have old code that continues to work as expected to verify that the ICEPIC works?
berler_d
PostPosted: Thu Jun 17, 2004 12:14 am     Reply with quote
Hi Nutone,
I started to check it and found these results:
The ICEPIC works fine with old CCS compiler, you can debug and look at the code.
In the new CCS version it seems that the code is loaded and run , but you cant debug it because you cant see the LST or the source code.
you can only see the disassembler (and it dosent help).
prwatCCS
PostPosted: Thu Jun 17, 2004 2:09 am     Reply with quote
PLEASE tell us whihc versions of everything you are using.
CCS old and new, Icepic .. without that its hard to relate to anyone else's experience and/or setup.
Peter Willis
Development Director
Howard Eaton Lighting Ltd UK
berler_d
PostPosted: Thu Jun 17, 2004 2:17 am     Reply with quote
The old verson is: 2.454 (cod with no .)
The new version is: 8.02
Using ICEPIC2 with newest software 2.13
Please note that I cant see the code tracking or list, just the disassembler window.
berler_d
PostPosted: Sun Jun 20, 2004 12:25 am     Reply with quote
anyone has an answer ???
berler_d
PostPosted: Mon Jun 21, 2004 3:59 am     Reply with quote
