berler_d
ICEPIC & CCS |
Posted: Wed Jun 16, 2004 6:59 am |
Hi All,
Does CCS supports the ICEPIC ?
I tested the .cod of the latest version and found that it dosent work.
(In the past it worked)
What can be done about it ? |
Neutone
Posted: Wed Jun 16, 2004 8:21 am |
Did you try both versions of the .cod that are supported? |
Posted: Wed Jun 16, 2004 8:51 am |
Yes, I tryed both and it didnt work.
(In the past the .cod worked fine with ICEPIC)
Do you have any Idia how to solve this problem .. |
Neutone
Posted: Wed Jun 16, 2004 8:58 am |
Do you have old code that continues to work as expected to verify that the ICEPIC works? |
berler_d
Posted: Thu Jun 17, 2004 12:14 am |
Hi Nutone,
I started to check it and found these results:
The ICEPIC works fine with old CCS compiler, you can debug and look at the code.
In the new CCS version it seems that the code is loaded and run , but you cant debug it because you cant see the LST or the source code.
you can only see the disassembler (and it dosent help). |
prwatCCS
Joined: 10 Dec 2003 Posts: 67 Location: West Sussex, UK
Posted: Thu Jun 17, 2004 2:09 am |
PLEASE tell us whihc versions of everything you are using.
CCS old and new, Icepic .. without that its hard to relate to anyone else's experience and/or setup. _________________ Peter Willis
Development Director
Howard Eaton Lighting Ltd UK |
berler_d
Posted: Thu Jun 17, 2004 2:17 am |
The old verson is: 2.454 (cod with no .)
The new version is: 8.02
Using ICEPIC2 with newest software 2.13
Please note that I cant see the code tracking or list, just the disassembler window. |
berler_d
Posted: Sun Jun 20, 2004 12:25 am |
anyone has an answer ??? |
berler_d
Posted: Mon Jun 21, 2004 3:59 am |
