Posted: Sun May 23, 2004 10:05 pm |
Actually, a few days ago I was checking the Piclist archives, searching
for an answer to his question. I searched for keywords: 16F877, reset,
MCLR, etc., and what I found there suggested that it was a problem
with the LVP fuse being set.
However, I didn't post it because the schematic seemed so screwed
up that who knows what the real problem could be ? For example, he
had a 10 nf cap on the output of his voltage regulator, when it should
have been 10 UF. Then when I said you don't call the Microchipc
bootloader from main(), he just said he's always done it that way.
So, I gave up. One more input from me regarding the LVP fuse
wouldn't have made any difference, I felt. |
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Sun May 23, 2004 10:54 pm |
Actually I think his problem isn't solved yet. There were two instances that he claimed the problem was solved:
Quote: |
jejejeje Yes, it works. That isnīt the problem, forget the transistors
The problem is in MCLR (or that I think |
And
Quote: | Yes, thanks everybody, problem solved.
The board is perfect, all works perfectly (included transistors and buzzer , the problem was in the bootloader, it had enabled the LVP and didnīt allow that my programs change it.
Well that looks like it was a software issue. But earlier he had claimed that his hand-wired board works while the PCBs don't. That software issue should have affected both the same... |
Helyos
Yes |
Posted: Mon May 24, 2004 5:28 am |
Yes, you are rigth. In my hand wired board, it worked, but I remember that in my test board I have pullups in all pins. That was my mistake in my board, I donīt put pullups in all. RB4 was working wrong.
The strange is when I connect the keyb, where I have the pullups connected and it didnīt work neither.
But... NOW WORKS, thatīs the important, thanks |
