MCLR doesnīt restart the code (include schematics) Why?
Goto page Previous  1, 2, 3, 4
PostPosted: Sun May 23, 2004 10:05 pm     Reply with quote
Actually, a few days ago I was checking the Piclist archives, searching
for an answer to his question. I searched for keywords: 16F877, reset,
MCLR, etc., and what I found there suggested that it was a problem
with the LVP fuse being set.
However, I didn't post it because the schematic seemed so screwed
up that who knows what the real problem could be ? For example, he
had a 10 nf cap on the output of his voltage regulator, when it should
have been 10 UF. Then when I said you don't call the Microchipc
bootloader from main(), he just said he's always done it that way.
So, I gave up. One more input from me regarding the LVP fuse
wouldn't have made any difference, I felt.
Haplo
PostPosted: Sun May 23, 2004 10:54 pm     Reply with quote
Actually I think his problem isn't solved yet. There were two instances that he claimed the problem was solved:
jejejeje Yes, it works. That isnīt the problem, forget the transistors
The problem is in MCLR (or that I think
And
Yes, thanks everybody, problem solved.
The board is perfect, all works perfectly (included transistors and buzzer , the problem was in the bootloader, it had enabled the LVP and didnīt allow that my programs change it.
Well that looks like it was a software issue. But earlier he had claimed that his hand-wired board works while the PCBs don't. That software issue should have affected both the same...
Helyos
Yes
PostPosted: Mon May 24, 2004 5:28 am     Reply with quote
Yes, you are rigth. In my hand wired board, it worked, but I remember that in my test board I have pullups in all pins. That was my mistake in my board, I donīt put pullups in all. RB4 was working wrong.
The strange is when I connect the keyb, where I have the pullups connected and it didnīt work neither.
But... NOW WORKS, thatīs the important, thanks Laughing
Page 4 of 4
