Passing structure problem!! It's BuG?
micman
PostPosted: Mon May 10, 2004 6:16 am     Reply with quote
Hi all,
I have problem with passing structure at the function,example code:
#include "C:\5\ffv.h"
#int_RTCC
RTCC_isr()
struct sgara gara;
port_b_pullups(TRUE);
setup_adc_ports(RA0_ANALOG);
setup_psp(PSP_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_1,255,1);
setup_ccp1(CCP_PWM);
enable_interrupts(INT_RTCC);
gara.mt = 50;
intet(&gara);
void intet(struct sgara gara){
int8 mt1;
int8 *ptr;
ptr = (int8 *)gara; //ptr = 0x4517
mt1 = gara.mt;
intet1(&gara);
void intet1(struct sgara gara){
int8 mt1;
int8 *ptr;
ptr = (int8 *)gara; //PROBLEM!!!!!! it's bug? ptr = 0x4918
mt1 = gara.mt; // error passing!!! mt1 = 18
intet2(&gara);
void intet2(struct sgara gara){
int8 mt1;
int8 *ptr;
ptr = (int8 *)gara; //ptr = 0x3211
mt1 = gara.mt; //mt1 = 1c
intet3(&gara);
void intet3(struct sgara gara){
int8 mt1;
int8 *ptr;
ptr = (int8 *)gara; //ptr = 0x4520
mt1 = gara.mt; //mt1 = 0x20
//File header
#include <18F452.h>
#device ICD=TRUE
#device adc=8
#fuses NOWDT,WDT128,HS, NOPROTECT, NOOSCSEN, BROWNOUT, BORV42, PUT, STVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9)
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3)
//Strutture
struct sgara {
int8 mt;
void intet(struct sgara gara);
void intet1(struct sgara gara);
void intet2(struct sgara gara);
void intet3(struct sgara gara);
mvaraujo
PostPosted: Mon May 10, 2004 7:21 am     Reply with quote
Let me ask you this: Is it necessary for you to pass the structure?
Darren Rook
PostPosted: Mon May 10, 2004 7:38 am     Reply with quote
Instead of passing the structure, pass a pointer to the structure. It's more effecient that way.
PostPosted: Mon May 10, 2004 7:51 am     Reply with quote
This is actually, where he is going wrong!.
He is passing a pointer, but has declared in the subroutine that he is passing the actual structure...
The two statements involved are:
intet(&gara);
in main, and:
The first says 'pass the address of this structure', while the second tells the routine to expect the structure itself. The code needs to either be changed to pass the structure, or to expect the pointer...
micman
PostPosted: Mon May 10, 2004 7:58 am     Reply with quote
as I can change the code for passisng the structure o the pointer at the structure?
Haplo
PostPosted: Mon May 10, 2004 5:25 pm     Reply with quote
Sure. For example, your first function should look like this:
void intet(struct sgara * gara){
int8 mt1;
int8 *ptr;
mt1 = gara->mt;
intet1(gara);
Darren Rook
PostPosted: Mon May 10, 2004 6:37 pm     Reply with quote
Oops. Embarassed
