micman Guest
| Passing structure problem!! It's BuG? |
Posted: Mon May 10, 2004 6:16 am |
Hi all,
I have problem with passing structure at the function,example code:
#include "C:\5\ffv.h"
#int_RTCC
RTCC_isr()
struct sgara gara;
port_b_pullups(TRUE);
setup_adc_ports(RA0_ANALOG);
setup_psp(PSP_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_1,255,1);
setup_ccp1(CCP_PWM);
enable_interrupts(INT_RTCC);
gara.mt = 50;
intet(&gara);
void intet(struct sgara gara){
int8 mt1;
int8 *ptr;
ptr = (int8 *)gara; //ptr = 0x4517
mt1 = gara.mt;
intet1(&gara);
void intet1(struct sgara gara){
int8 mt1;
int8 *ptr;
ptr = (int8 *)gara; //PROBLEM!!!!!! it's bug? ptr = 0x4918
mt1 = gara.mt; // error passing!!! mt1 = 18
intet2(&gara);
void intet2(struct sgara gara){
int8 mt1;
int8 *ptr;
ptr = (int8 *)gara; //ptr = 0x3211
mt1 = gara.mt; //mt1 = 1c
intet3(&gara);
void intet3(struct sgara gara){
int8 mt1;
int8 *ptr;
ptr = (int8 *)gara; //ptr = 0x4520
mt1 = gara.mt; //mt1 = 0x20
//File header
#include <18F452.h>
#device ICD=TRUE
#device adc=8
#fuses NOWDT,WDT128,HS, NOPROTECT, NOOSCSEN, BROWNOUT, BORV42, PUT, STVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9)
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3)
//Strutture
struct sgara {
int8 mt;
void intet(struct sgara gara);
void intet1(struct sgara gara);
void intet2(struct sgara gara);
void intet3(struct sgara gara); |
mvaraujo
Posted: Mon May 10, 2004 7:21 am |
| Let me ask you this: Is it necessary for you to pass the structure? |
Darren Rook
Joined: 06 Sep 2003 Posts: 287 Location: Milwaukee, WI
Posted: Mon May 10, 2004 7:38 am |
| Instead of passing the structure, pass a pointer to the structure. It's more effecient that way. |
Posted: Mon May 10, 2004 7:51 am |
| Darren Rook wrote: | | Instead of passing the structure, pass a pointer to the structure. It's more effecient that way. |
This is actually, where he is going wrong!.
He is passing a pointer, but has declared in the subroutine that he is passing the actual structure...
The two statements involved are:
intet(&gara);
in main, and:
The first says 'pass the address of this structure', while the second tells the routine to expect the structure itself. The code needs to either be changed to pass the structure, or to expect the pointer...
micman Guest
Posted: Mon May 10, 2004 7:58 am |
as I can change the code for passisng the structure o the pointer at the structure?
Thanks |
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Mon May 10, 2004 5:25 pm |
Sure. For example, your first function should look like this:
| Quote: |
void intet(struct sgara * gara){
int8 mt1;
int8 *ptr;
mt1 = gara->mt;
intet1(gara);
Darren Rook
Posted: Mon May 10, 2004 6:37 pm |
| Ttelmah wrote: | This is actually, where he is going wrong!.
Oops.  |
