acsg
Joined: 25 Apr 2021 Posts: 8 Location: Rio de Janeiro - Brazil
Show 8 bytes hex to lcd |
Posted: Fri Aug 13, 2021 9:07 am |
Hi Guys,
My problem is: I can't show the entire hex code on LCD ...
#include <16F88.h>
#fuses NOWDT,NOPROTECT,PUT,NOLVP, NOMCLR,INTRC_IO, NODEBUG
#use delay(clock = 8MHz)
#use i2c(Master,Fast=100000, sda=PIN_B1, scl=PIN_B4,force_sw)
#include "i2c_Flex_LCD.c"
unsigned int32 code;
setup_oscillator(OSC_8MHZ); // Set internal oscillator to 8MHz
lcd_init(0x7E,16,2);
lcd_backlight_led(ON); //Underground light
printf(lcd_putc, "\fTeste Hex"); // "Text hex" shown normally
code = 0x3FCF00FF;
while(TRUE){
if(code == 0x3FCF00FF)
output_toggle(LED);
printf(lcd_putc, "\f%X",code);
// After that LCD shows "FF". If i use "\f%8X", i see 000000FF. I should see "3FCF00FF" _________________ "For by wise counsel you will wage your own war."
Pv24:6 |
gaugeguy
Posted: Fri Aug 13, 2021 9:59 am |
%X is for 8 bit values, you want %lX for a long hex value |
Joined: 01 Jul 2010 Posts: 9142 Location: Greensville,Ontario
Posted: Fri Aug 13, 2021 10:23 am |
BTW that's a lower case 'L'...not the number '1'.
Can be confusing depending on monitor, font, colour and when the coffeepot's empty.... |
acsg
Posted: Fri Aug 13, 2021 12:47 pm |
Guys, SOLVED !
God bless you very much !! _________________ "For by wise counsel you will wage your own war."
Pv24:6 |
