Show 8 bytes hex to lcd
acsg
PostPosted: Fri Aug 13, 2021 9:07 am     Reply with quote
Hi Guys,
My problem is: I can't show the entire hex code on LCD ...
#include <16F88.h>
#fuses NOWDT,NOPROTECT,PUT,NOLVP, NOMCLR,INTRC_IO, NODEBUG
#use delay(clock = 8MHz)
#use i2c(Master,Fast=100000, sda=PIN_B1, scl=PIN_B4,force_sw)
#include "i2c_Flex_LCD.c"
unsigned int32 code;
void main() {
  setup_oscillator(OSC_8MHZ);              // Set internal oscillator to  8MHz
  lcd_init(0x7E,16,2);
  lcd_backlight_led(ON); //Underground light
  printf(lcd_putc, "\fTeste Hex");  // "Text hex" shown normally
 code = 0x3FCF00FF;
     while(TRUE){
      if(code == 0x3FCF00FF)
          output_toggle(LED);
          printf(lcd_putc, "\f%X",code);
// After that LCD shows "FF". If i use "\f%8X", i see 000000FF. I should see "3FCF00FF"
"For by wise counsel you will wage your own war."
Pv24:6
gaugeguy
PostPosted: Fri Aug 13, 2021 9:59 am     Reply with quote
%X is for 8 bit values, you want %lX for a long hex value
PostPosted: Fri Aug 13, 2021 10:23 am     Reply with quote
BTW that's a lower case 'L'...not the number '1'.
Can be confusing depending on monitor, font, colour and when the coffeepot's empty....
acsg
PostPosted: Fri Aug 13, 2021 12:47 pm     Reply with quote
Guys, SOLVED !
God bless you very much !!
Pv24:6
