.cof file problem again
water_r
PostPosted: Tue Feb 17, 2004 7:11 pm     Reply with quote
hi, all,
I am using MPLAB 6.40 and PCW 1.094v. Each time I clicked "compile", one small window always came out, stating "Failed to load xx.cof file".
This problem has been posted before. Do anyone know the solution? Thanks in advance.
PostPosted: Tue Feb 17, 2004 9:35 pm     Reply with quote
This thread gives two possible solutions.
I had this problem and fixed it by the 2nd one.
ie., Remove printf statements until the error goes away.
http://www.ccsinfo.com/forum/viewtopic.php?t=6292&highlight=failed+load+cof
water_river
failed to load .cod file instead??
PostPosted: Tue Feb 17, 2004 10:53 pm     Reply with quote
When I removed the "printf" statements, it still failed to load the .cof file.
But as I right clicked the c file and changed the Debug Option to "none", it became "failed to load the .cod file" instead ???
BTW, My compiler is PCW3.094
tmach
Re: failed to load .cod file instead??
PostPosted: Wed Feb 18, 2004 6:55 pm     Reply with quote
I had a similar bad experience last week. This problem started when I installed MPLAB 6.40 without removing MPLAB 6.1 that was on my syatem. Then I had to remove all previous installations and reinstall MPLAB 6.40 and the problem disappeared.
Hope this works out for our case.
