water_r Guest
| .cof file problem again |
Posted: Tue Feb 17, 2004 7:11 pm |
hi, all,
I am using MPLAB 6.40 and PCW 1.094v. Each time I clicked "compile", one small window always came out, stating "Failed to load xx.cof file".
This problem has been posted before. Do anyone know the solution? Thanks in advance. |
water_river
| failed to load .cod file instead?? |
Posted: Tue Feb 17, 2004 10:53 pm |
When I removed the "printf" statements, it still failed to load the .cof file.
But as I right clicked the c file and changed the Debug Option to "none", it became "failed to load the .cod file" instead ???
BTW, My compiler is PCW3.094 |
tmach
| Re: failed to load .cod file instead?? |
Posted: Wed Feb 18, 2004 6:55 pm |
I had a similar bad experience last week. This problem started when I installed MPLAB 6.40 without removing MPLAB 6.1 that was on my syatem. Then I had to remove all previous installations and reinstall MPLAB 6.40 and the problem disappeared.
Hope this works out for our case. |
