How to write value 300 to eeprom ?
gopi
PIC 16f877a EEPROM Accessing
PostPosted: Sat May 23, 2015 3:10 am     Reply with quote
Good morning..
I have PIC 16f877a. Now i write the value 300 in this pic EEPROM
I am using following Syntax its only store the value 0 to 255.
so Pls Guid to store the value of 300 in this pic eeprom.
write_eeprom (0x00,300);
i=read_eeprom (0x00);
PostPosted: Sat May 23, 2015 7:11 am     Reply with quote
you need to write a WORD
in 2 bytes of EEPROM
see the MAKE8() function
PostPosted: Sun May 24, 2015 1:19 am     Reply with quote
As a further comment, try reading the manual.....
Section:
"How do I write variables to EEPROM that are not a byte?" and the example this links to.
jeremiah
PostPosted: Sun May 24, 2015 10:39 am     Reply with quote
I gave you an answer in your duplicate thread as well:
https://www.ccsinfo.com/forum/viewtopic.php?t=53948
gopi
PostPosted: Tue May 26, 2015 9:47 am     Reply with quote
I have use to print above 255 value in PIC 16f877a eeprom.
syntax:
write_program_eeprom(address,data);
value=read_program_eeprom(address);
its work correctly.
gopi
How to store string in PIC 16f877a eeprom
PostPosted: Tue May 26, 2015 9:48 am     Reply with quote
How to store string in PIC 16f877a eeprom.
Pls send the syntax.
PostPosted: Tue May 26, 2015 10:34 am     Reply with quote
Simply create a function to compute the length of the string and then store each byte of the string until you get to the 'end of string' character which is a null (0).
I leave it to you to look at the string functions CCS supplies as I assume this is a school project as the 877 is, well, obsolete !
Jay
