PIC 16f877a EEPROM Accessing
gopi
PostPosted: Sat May 23, 2015 7:17 am     Reply with quote
Good morning..
I have PIC 16f877a. Now i write the value 300 in this pic EEPROM
I am using following Syntax its only store the value 0 to 255.
so Pls Guid to store the value of 300 in this pic eeprom.
write_eeprom (0x00,300);
i=read_eeprom (0x00);
pls send the syntax
PostPosted: Sat May 23, 2015 7:42 am     Reply with quote
300 is not an int8 value (0-255 are int8 values).
You either need to use an int16 value and split it/merge it:
unsigned int16 value = 300;
unsigned int16 result = 0;
write_eeprom(0x00,make8(value,1));
write_eeprom(0x01,make8(value,0));
result = make16(read_eeprom(0x00),
                read_eeprom(0x01));
or if the compiler has pointer/length write_eeprom and read_eeprom support for your chip:
write_eeprom(0x00,&value,sizeof(unsigned int16));
read_eeprom(0x00,&result,sizeof(unsigned int16));
