atoo
| arrays |
Posted: Fri Jan 31, 2014 5:26 pm |
I'm Brazilian,
and practice the language ccs.
My doubt is about arrays.
How to do the picture with using 8x8 LED arrays?
Thank you all.
Can someone post an example ? |
atoo
Posted: Sat Feb 01, 2014 5:49 pm |
| thank you! |
atoo
| thank you, I'm trying do of this way |
Posted: Sat Feb 01, 2014 6:00 pm |
| Code: | #include <16f88.h>
#fuses XT,NOWDT,NOLVP,PUT,NOBROWNOUT
#define max 50
#use fast_io(a)
#use fast_io(b)
int i,j,min=0,maxi=8,cont=0;
int const data[208]=//not ! |
with arrays I want understood?
| Code: | {48,120,204,204,252,204,204,204,248,204,204,248,248,204,204,248,252,
192,192,192,192,192,192,252,240,200,204,204,204,204,200,240,252,192,192,240,240,192,192,252,252,
192,192,240,240,192,192,192,60,64,192,192,216,204,204,248,204,204,204,204,252,204,204,204,252,
48,48,48,48,48,48,252,252,48,48,48,48,48,176,224,196,200,208,224,208,204,204,204,192,
192,192,192,192,192,192,252,238,214,214,198,198,198,198,198,196,228,244,212,212,204,204,196,48,
204,204,204,204,204,204,48,248,204,204,204,248,192,192,192,56,196,196,196,196,212,200,52,248,
204,204,204,248,208,200,196,120,204,192,192,120,12,12,248,252,48,48,48,48,48,48,48,204,
204,204,204,204,204,204,120,204,204,204,204,204,204,72,48,198,198,198,198,198,214,214,238,132,
132,72,48,48,72,132,132,204,204,204,120,48,48,48,48,252,252,8,16,32,64,252,252};
//int enie[8]={56,196,228,244,212,204,204,196};
void main() |
Mike Walne
Posted: Sun Feb 02, 2014 11:31 am |
1) What are you trying to do?
2) Are you using REAL hardware or SIMULATION.
3) Show us a schematic or list pin connections.
4) Read CCS forum guideline.
5) Which compiler version are you using.
Mike |
atoo
| TUDO BEM? |
Posted: Sun Feb 02, 2014 9:27 pm |
eu estou usando CCS C 4.114
I wonder if it is possible
make an array or image to be recognized
using an A / D ??
shot in then a photograph and in then compares images
Mike Walne
Posted: Mon Feb 03, 2014 9:53 am |
1) What is your coding experience?
2) Have you tried any of the CCS examples?
3) Are you using real hardware or computer simulation?
Mike |
atoo
| arrays |
Posted: Wed Feb 05, 2014 10:57 pm |
yes, I've used proteus.
My language is practiced in this multiplexing.
How to avoid the consumption of memory RAM ?
Put const consume little memory? in int?
//irmão gostaria de consumir pouca memória RAM
// brother would like to consume little memory RAM
atoo
Posted: Thu Feb 06, 2014 2:00 am |
Yes, you can use 'const'.
Beware though, on your chip, you can't construct pointers to data contained in ROM (your chip does not have the ability to do this). When you use 'const', the compiler actually generates a small program that will when called with an 'address', return the value required from this address. So your code as shown will work, but some more complex constructions won't.
Why not just test things?.
Seriously, beware of Proteus. It can be very misleading about what will and won't work when dealing with the PIC hardware. On your chip unlikely to be a problem, but on more complex chips it habitually will tell you things won't work (that do in real chips), and that things will work (that can't...). This is why there is the 'sticky' at the top of the forum telling people that we won't answer Proteus questions....
Mike Walne
| Re: arrays |
Posted: Thu Feb 06, 2014 5:21 am |
| atoo wrote: | | yes, I've used proteus. | Proteus / ISIS questions are banned on this forum.
Get some real hardware and have a play with it.
You will learn a lot more.
If/when you get stuck someone here will be willing to help.
Mike |
atoo
| atoo |
Posted: Thu Feb 06, 2014 8:25 pm |
I understand now thanks to all
moderator can close the topic
problem solved !!
earned personal !!
thank you!
Charles francês joao pessoa PB |
