arrays
atoo
arrays
PostPosted: Fri Jan 31, 2014 5:26 pm     Reply with quote
I'm Brazilian,
and practice the language ccs.
My doubt is about arrays.
How to do the picture with using 8x8 LED arrays?
Thank you all.
Can someone post an example ?
PostPosted: Sat Feb 01, 2014 12:14 am     Reply with quote
Use the forum's search page, here:
http://www.ccsinfo.com/forum/search.php
Search for this:
8x8 matrix
Make sure that you select this option:
Search for all terms
atoo
PostPosted: Sat Feb 01, 2014 5:49 pm     Reply with quote
thank you!
atoo
thank you, I'm trying do of this way
PostPosted: Sat Feb 01, 2014 6:00 pm     Reply with quote
#include <16f88.h>
#fuses XT,NOWDT,NOLVP,PUT,NOBROWNOUT
#define max 50
#use fast_io(a)
#use fast_io(b)
int i,j,min=0,maxi=8,cont=0;
int const data[208]=//not  !
with arrays I want understood?
{48,120,204,204,252,204,204,204,248,204,204,248,248,204,204,248,252,
192,192,192,192,192,192,252,240,200,204,204,204,204,200,240,252,192,192,240,240,192,192,252,252,
192,192,240,240,192,192,192,60,64,192,192,216,204,204,248,204,204,204,204,252,204,204,204,252,
48,48,48,48,48,48,252,252,48,48,48,48,48,176,224,196,200,208,224,208,204,204,204,192,
192,192,192,192,192,192,252,238,214,214,198,198,198,198,198,196,228,244,212,212,204,204,196,48,
204,204,204,204,204,204,48,248,204,204,204,248,192,192,192,56,196,196,196,196,212,200,52,248,
204,204,204,248,208,200,196,120,204,192,192,120,12,12,248,252,48,48,48,48,48,48,48,204,
204,204,204,204,204,204,120,204,204,204,204,204,204,72,48,198,198,198,198,198,214,214,238,132,
132,72,48,48,72,132,132,204,204,204,120,48,48,48,48,252,252,8,16,32,64,252,252};
//int enie[8]={56,196,228,244,212,204,204,196};
Mike Walne
PostPosted: Sun Feb 02, 2014 11:31 am     Reply with quote
1) What are you trying to do?
2) Are you using REAL hardware or SIMULATION.
3) Show us a schematic or list pin connections.
4) Read CCS forum guideline.
5) Which compiler version are you using.
Mike
atoo
TUDO BEM?
PostPosted: Sun Feb 02, 2014 9:27 pm     Reply with quote
eu estou usando CCS C 4.114
I wonder if it is possible
make an array or image to be recognized
using an A / D ??
shot in then a photograph and in then compares images
Mike Walne
PostPosted: Mon Feb 03, 2014 9:53 am     Reply with quote
1) What is your coding experience?
2) Have you tried any of the CCS examples?
3) Are you using real hardware or computer simulation?
Mike
atoo
arrays
PostPosted: Wed Feb 05, 2014 10:57 pm     Reply with quote
yes, I've used proteus.
My language is practiced in this multiplexing.
How to avoid the consumption of memory RAM ?
Put const consume little memory? in int?
//irmão gostaria de consumir pouca memória RAM Question
// brother would like to consume little memory RAM Question
atoo
PostPosted: Thu Feb 06, 2014 2:00 am     Reply with quote
Yes, you can use 'const'.
Beware though, on your chip, you can't construct pointers to data contained in ROM (your chip does not have the ability to do this). When you use 'const', the compiler actually generates a small program that will when called with an 'address', return the value required from this address. So your code as shown will work, but some more complex constructions won't.
Why not just test things?.
Seriously, beware of Proteus. It can be very misleading about what will and won't work when dealing with the PIC hardware. On your chip unlikely to be a problem, but on more complex chips it habitually will tell you things won't work (that do in real chips), and that things will work (that can't...). This is why there is the 'sticky' at the top of the forum telling people that we won't answer Proteus questions....
Smile
Mike Walne
Re: arrays
PostPosted: Thu Feb 06, 2014 5:21 am     Reply with quote
Proteus / ISIS questions are banned on this forum.
Get some real hardware and have a play with it.
You will learn a lot more.
If/when you get stuck someone here will be willing to help.
Mike
atoo
atoo
PostPosted: Thu Feb 06, 2014 8:25 pm     Reply with quote
I understand now thanks to all
moderator can close the topic
problem solved !!
earned personal !!
thank you! Surprised
Charles francês joao pessoa PB
