[Solved] Can't initialize int48
haxan7
PostPosted: Sat Sep 28, 2013 12:06 am     Reply with quote
Compiler Version: 4.140
PIC: 18lf46k22
Why can't i initialize any variable greater than 48 bit in size?
PostPosted: Sat Sep 28, 2013 12:16 am     Reply with quote
Why do you think an int48 data type is supported for that PIC and that
compiler version ? If I install vs. 4.140 and try to compile the program
shown below I get errors. It's not supported.
#include <18LF46K22.h>
#fuses INTRC_IO, NOWDT
#use delay(clock=4M)
int48 temp;
haxan7
PostPosted: Sat Sep 28, 2013 12:20 am     Reply with quote
compiler version ?
I don't for sure, but i found this http://www.ccsinfo.com/content.php?page=syntax-functions.
It says that "int48" is for "PIC10 – PIC18 compilers only";
PostPosted: Sat Sep 28, 2013 12:22 am     Reply with quote
int48, int64, float 64 etc., are _PCD_ features only. The PIC18/16 compiler does not support them.
You can initialise variables any size you want (structures etc.), but you would have to declare them, and generate the code to handle them.
I'd suspect CCS are intending to add them. I have asked in the past, particularly for the larger integer types. Historically, the V3, and V4 manuals don't mention them in pcb/pcm/pch, only listing them if you have pcd. With V5, then have been added to the manuals, but don't yet work.
PostPosted: Sat Sep 28, 2013 12:29 am     Reply with quote
No it doesn't. That note is for an Orange asterisk. That refers to the list of functions.
The data types such as int48 and int64 are marked with a pink asterisk.
That note says:
Items marked with * are for 24-bit parts only.
Which is not for your PIC.
This colored asterisk stuff is crazy. CCS should have used numbered
superscripts, which is the way Microchip does it in their data sheets.
haxan7
PostPosted: Sat Sep 28, 2013 12:37 am     Reply with quote
Thanks a lot guys. I was going to store phone number in an int, i guess i will have to use char array instead.
alan
PostPosted: Sat Sep 28, 2013 12:44 am     Reply with quote
Why not use a struct and store area code and number seperate. That way you can still use ints and save on ram.
Regards
PostPosted: Sat Sep 28, 2013 1:24 am     Reply with quote
The manual inside the compiler, for V5, doesn't distinguish the types at all.
If you open the page 'basic and special types', no mention is made of what compilers can support what types. Given this is the PCB/M/H manual (not the PCD one), it really is designed to confuse...
Have to agree on the structure though.
mcr1981
About int48, int64, float48 and float64
PostPosted: Thu Jan 16, 2014 1:18 am     Reply with quote
Looks like I have some issue with this too Mr Ttelmah.
I'm moving to PCD from PCH (using MPLAB IDE, now MPLAB X).
I can see in the device file support for longer integers and floats:
#if (!defined(__PCD__)||defined(__ISNT_CCS__))
#define _bif
#define int8 char
#define int16 int
#define int32 long
#define int48 long
#define int64 long long
#define float32 float
#define float48 float
#define float64 double
#define int1 char
I'm using a simple program to declare variables and see their length. However, MPLAB X only shows 32 bit variables (four Bytes) for long long (int64) and double (float64).
I might be using it wrong since I'm new to PCD, but I think I'm right; unless you have to declare something to specify that you want this to compile for a PCD device other than the header file of the device.
I had some trouble with an LCD connection but got it working. Printed some info to it (float) and was not what I expected.
1/3 = 0.33 and the LCD showed 0.00; forced 1.0/3.0 and showed it correctly.
I do understand that sometimes you need to promote a variable or be specific about the operation you want, so I made a little program to test this in MPLAB X and to my surprise there were no 64 bit variables (you are right about the Data Definitions in the PCD manual).
PostPosted: Thu Jan 16, 2014 2:19 am     Reply with quote
What that code does is say that on non PCD compilers, treat an int48, _as_ a long, to prevent syntax errors, and the same for the other types.
The types are _native_ on PCD, and the code section you post won't be used.
When you select the variable and create the 'watch'. Right click on it and select 'properties'. You can then select the size, and format. It is just that the defaults in MPLAB are for the smaller sizes.
RF_Developer
PostPosted: Thu Jan 16, 2014 5:00 am     Reply with quote
Phone "numbers" are not numbers, but include symbols and are generally formatted. They often have leading zeros and are specific lengths. They are strings, not numbers. A typical phone number where I am is something like (I made this up, it's not a real phone number):
02973 231765
Also, especially on older telephone systems, other symbols were/are used to give pauses in the dialling to allow the phone system to do its thing. For example, from here at work, which is in the same area code, I'd dial:
9,231765
where the comma represents a pause to wait for the "outside" line.
for international use that would be:
+44 (2973) 231765
You cannot use ints for these. You need to treat it as a string, i.e. an array of char.
