Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
BMP085 Pressure Sensor
Goto page Previous  1, 2
ajt
PostPosted: Mon Sep 16, 2013 9:28 am     Reply with quote
waynewy wrote:
Just a quick question, where did you get the i2c library in order to use i2c_start(), i2c_write(), etc?
They are all built-in CCS functions.
Al Testani
waynewy
PostPosted: Mon Sep 16, 2013 9:44 am     Reply with quote
Forgive me that I am new to this forum. Where can I find those functions? I am actually trying to use PIC24E microcontrollers to interface with this sensor.
Thank you Al!
ajt
PostPosted: Mon Sep 16, 2013 9:56 am     Reply with quote
http://www.ccsinfo.com/content.php?page=syntax-functions, online help in the IDE, and/or the downloadable reference manual http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
What version of the compiler are you using?
Al Testani
waynewy
PostPosted: Mon Sep 16, 2013 9:58 am     Reply with quote
I am using MPLAB X with XC16 compiler.
I just downloaded MPLAB X plug-in. However, it seemed that I need more than that.
ajt
PostPosted: Mon Sep 16, 2013 10:01 am     Reply with quote
Yes, of course you do. You need the CCS compiler to use the built-in CCS functions!
Al Testani
waynewy
PostPosted: Mon Sep 16, 2013 10:02 am     Reply with quote
Understood! Thank you so much for your instructions. I will figure it out hopefully.
kaka khan
PostPosted: Sat Sep 28, 2013 5:21 am     Reply with quote
can anyone help me to program bmp085 with pic16f877
Hexadec
PostPosted: Tue Oct 15, 2013 1:29 pm     Reply with quote
Thanks for the code ajt, saved me a lot of time!
Working perfectly on 18F45K20 with LCD readout.
pathmasugu
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger ICQ Number
PostPosted: Wed Mar 19, 2014 4:22 am     Reply with quote
This code works good ..........thank you ajt.
ROCK RAJ
monix7
PostPosted: Sat Aug 22, 2015 5:25 am     Reply with quote
Dear friends,
I'm carrying out a project with a PIC18F2585 and various weather sensors, one of them the BMP180.
I copied the Testani's code, and the temperature reading seems to be OK, but it's strange the pressure reading, like -200 mBar, when it should be over +1000 mBar.
My home is few meters above sea level.
Should I change the : " #define P_CORRECTION 1.5 " or some of the calibration factors ??
I would be so grateful with any help.
anhanh
PostPosted: Tue Sep 22, 2015 9:39 pm     Reply with quote
please explain code for me // 160 * pow2(-15) * ac3;
PostPosted: Tue Sep 22, 2015 10:28 pm     Reply with quote
Look at page 2 in this document:
http://wmrx00.sourceforge.net/Arduino/BMP085-Calcs.pdf
It has the formula for c3. It's the same formula as you posted.
inservi
PostPosted: Mon Sep 26, 2016 8:20 am     Reply with quote
Thank-you, your code work very well with a 16F1825 :-)
Here is the Altitude function i added from arduino library
float BMP085pressureToAltitude(float seaLevel, float atmospheric) {
  // Equation taken from BMP180 datasheet (page 16):
  //  http://www.adafruit.com/datasheets/BST-BMP180-DS000-09.pdf
  // Note that using the equation from wikipedia can give bad results
  // at high altitude.  See this thread for more information:
  //  http://forums.adafruit.com/viewtopic.php?f=22&t=58064
  return 44330.0 * (1.0 - pow(atmospheric / seaLevel, 0.1903));
in m├ędio virtus
Page 2 of 2
