Gabriel
| About the Forum |
Posted: Mon May 06, 2013 8:21 am |
Hey Forum,
I was thinking about the Code Library and how much collective work there is in that part of this forum.
This got me thinking about how disorganized *WE* are, and by that I mean PIC users in general.
I know that is a very big generalization, but consider the following:
I think one of the great successes of Arduino is the standardization of “drivers” or at least their community’s code library organization. Even more, is how much people simply trust the code to work, and in fact it DOES.
Now, back to the Code Library, we know that everybody that posts “drivers” there tested their code at least once… or we trust they did.
But in reality we do not have any guarantees or indication of “Confidence Level” on how good that code is… I know “good code” is like a pretty girl… it depends on the eye of the beholder.
So how about maybe creating a *Certificate* of sorts and a new Code Library, where only code that has been tested and “approved” by at least 5 different Forum members gets posted by a moderator for example, with a list of the testers. This library is not open for comments or questions… it is simply a repository of *Certified* code.
Instead of posting similar drivers for the same part (for example the DS1307), the single *Certified* driver would now include the new functionality that has been recently added…
Code revisions would just improve or add completeness to the driver, not fork into 6 slightly different drivers.
This is Utopian at best… I know, but I wonder what you guys think.
After all it would be ALL OF US who would benefit from this.
I know we all work, dont have time, etc...
I often wonder what would be the most complex thing I could build using drivers straight of the library.
G. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Gabriel
Posted: Mon May 06, 2013 8:43 am |
Right of the bat i would suggest we ALL do an attempt to do this for a few parts like:
RTC's: DS1305 & DS1307
EEPROM's (IC2 and SPI - one driver for all sizes)
TEMP Sensors: LM35, DS18B20
ADC Sampling routines and other clever ones
LCD's
If this gets some kind of support, i will post my:
DS1305
25LC512
and we cant start on that...
LETS GET 5 CLEAN USEFULL DRIVERS, and see how it goes.
Gabriel
andrewg
Joined: 17 Aug 2005 Posts: 316 Location: Perth, Western Australia
Posted: Mon May 06, 2013 9:12 am |
At least part of the problem is that a web forum is a place for discussion, not a place for a code library.
A wiki would be a more appropriate place for a code library. The problem there is that it really needs to be set up by CCS. I mean, I could set up a wiki on my web site, but I'm just a random CCS user.
Of course, a wiki is good for a lot more than a code library... _________________ Andrew |
Gabriel
Posted: Mon May 06, 2013 9:28 am |
true.
however, we all hang around here... and to a point "know" each other,
we would not have to set up any infrastructure...or got to a diferent site.
the code can originate here, Selected here to be unified/cleaned here, and posted here...for use of people here...
This is our forum, our compiler, our code, and our collective job to keep it clean if one of us decides to open their code... is it not?
after all, your open code IS also MY code, no?
asmboy
Posted: Mon May 06, 2013 10:59 am |
one obvious problem that i and other posters have with your concept is this:
many drivers that i have created are either new original work for hire or repairs/mods to other pre-existing code. covered by confidentiality agreements.
when i can, i post code that is a non critical component of work for hire.
one example
http://www.ccsinfo.com/forum/viewtopic.php?t=47110&highlight=ad9850%2A
is a VERY stripped down subset of a DUAL 9850 driver that produces phase locked quadrature signal sources for a synchronous demodulator, guaranteed accurate to one cycle of the master source clock for the pair of chips. works great, customer loves it.....
but i can not ethically or contractually give that code away .
most of my drivers are that way.
I think you will find many other code contributors with similar situations.
ALSO
i have found many examples in the library that are knee deep in sketchy
coding that i would not begin to consider using. |
Gabriel
Posted: Mon May 06, 2013 11:19 am |
totally valid point but my intention is NOT to make others breach their contracts.
I have "generic" drivers I reuse and try to improve on from time to time.
I am sure you do too.
it is those OPEN non-contract-bound code we could Collectively improve on.
or Write New ones for the forum
my intention is precisely to eliminate the "Sketchy" codes and to start creating a library of "drivers" that have a General approval of the forum.
A Filter.
a clear example of such type of driver would be PCM's Flex_LCD.
I'm am sure EVERYBODY including you agrees its a reliable driver.
I am sure PCM is not infallible, however his driver has passed the test of time and i think the general consensus of the forum is that its not Sketchy.
i use it, and it worked right out of the forum... compiled, BAM! LCD on all my proyects... that simple.
Ive posted a few drivers myself, and I am the first one to admit they are not perfect, but my drivers and others can benefit from a others testing and improving until there is a Non-sketchy Generic driver that works well.
Like i said earlier... lets get a few Generic parts and lets make drivers for those...
there is plenty to build on here... lets agree on a few sketchy drivers, and clean them up.
Most of us don't need the fast Fourier transforms some user made for NASA.
but we ALL use RTC's, EEPROMS, Sensors, etc... simple stuff that we should not be coding over and over again.
