FAST F2C C2F temperature converts - no floats - no division
asmboy
PostPosted: Fri Apr 26, 2013 2:00 pm     Reply with quote
fast temperature conversion no float no division
fast computed , "good enough accuracy" temperature conversion:
Temperatures in the range of 32.0 deg F ,  Upwards to 6553.5 deg F
ie:                             0 deg C to 3623.0 C
the temperature in this system is represented as
10X the value of  degrees and tenths   so 50.0 deg becomes 500 etc
You will need to adjust the print formatting for the high temp end of
this range
much faster than floating point
//      conversion of 10x  temps
//      IN: deg F10x   OUT: deg C10X
//      residual output error at 986 input  +.03%
unsigned int16 DegFtoC(unsigned int16 degf_in){
  unsigned int32 t1;
  t1= (unsigned int32 ) (degf_in-320);
  t1 *=569;
  return (t1>>10);  // effective /1024
//      IN: deg C10x   OUT: deg F10X
//      residual output error at 370 input   -.01%
unsigned int16 DegCtoF(unsigned int16 degC_in){
  unsigned int32 t1=1843;
  t1 *= degC_in;
  t1 >>=10;  // divide 1024
  return ( t1+320); // add C-F offset  in our units
 // typical useage
    unsigned int16 tempf=986;  // 98.6 degreres F
    printf("Deg C %3.1w  Deg F %3.1w  \r\n", DegFtoC(tempf), tempf);
 // outputs Deg C 37.0   Deg F  98.6
