ex13b.c problem to run
Requan
PostPosted: Tue May 15, 2012 1:51 am     Reply with quote
Dear all,
I bought CCS 3.3V Ethernet Controler development kit.
I tried to run ex13b.c file (without change anything) but i get errors as follow:
    >>> Warning 201 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 189(1,1): Assignment inside relational expression
    --- Info 300 "C:\Program Files\PICC\drivers\string.h" Line 15(7,13): More info: First Declaration of strupr
    *** Error 31 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 302(1,2): Identifier is already used in this scope
    *** Error 48 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 306(7,8): Expecting a (
    *** Error 48 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 306(9,10): Expecting a (
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 307(5,10): Expecting a declaration
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 307(10,11): Expecting a declaration
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 307(12,13): Expecting a declaration
    *** Error 48 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 307(15,16): Expecting a (
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 307(17,18): Expecting a declaration
    *** Error 48 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 307(18,19): Expecting a (
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 307(21,22): Expecting a declaration
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 308(5,6): Expecting a declaration
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(9,11): Expecting a declaration
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(12,13): Expecting a declaration
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(14,15): Expecting a declaration
    *** Error 48 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(17,18): Expecting a (
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(20,23): Expecting a declaration
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(24,26): Expecting a declaration
    *** Error 48 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(29,30): Expecting a (
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(32,35): Expecting a declaration
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(35,36): Expecting a declaration
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(37,38): Expecting a declaration
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 310(13,14): Expecting a declaration
    *** Error 48 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 310(16,17): Expecting a (
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 310(19,20): Expecting a declaration
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 310(20,23): Expecting a declaration
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 310(24,25): Expecting a declaration
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 310(26,29): Expecting a declaration
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 310(29,30): Expecting a declaration
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 310(30,31): Expecting a declaration
    *** Error 48 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 311(5,6): Expecting a (
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 311(8,9): Expecting a declaration
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 312(5,6): Expecting a declaration
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 313(5,11): Expecting a declaration
    *** Error 48 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 313(12,13): Expecting a (
    *** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 314(1,2): Expecting a declaration
    35 Errors, 1 Warnings.
    Build Failed.
I don't understand because i checked and this functions have declaration.
Best Regards,
Martin
stoyanoff
PostPosted: Tue May 15, 2012 4:27 am     Reply with quote
Paste lines 302 to 314. I suppose you've made an error with copying the code.
Stoyanoff
Requan
PostPosted: Tue May 15, 2012 5:45 am     Reply with quote
Thanks for reply.
Here You are:
char *strupr (char *s)
    char c;
    char *t;
    t = s;
    while( (c = *t) )
        if ( (c >= 'a' && c <= 'z') )
            *t -= ('a' - 'A');
    t++;
    return s;
I use PIC 18F67J60 and of course set proper value in ccstcpip.h.
I didn't change anything. i run example only.
Requan
PostPosted: Thu May 17, 2012 3:17 am     Reply with quote
When I remove this function it solved problem.
stoyanoff
PostPosted: Thu May 17, 2012 3:37 am     Reply with quote
It's impossible the name of a function to be a pointer. Remove the "*" from the name of the function.
Stoyanoff
jeremiah
PostPosted: Thu May 17, 2012 6:14 am     Reply with quote
He's returning a char*...the function name is fine. Based on the errors though, it sounds like strupr is already defined somewhere. Try just changing the name to strupr2 and see if it compiles.
Requan
PostPosted: Tue May 22, 2012 7:34 am     Reply with quote
Arrow jeremiah
Yes it helps. Thank You
