Requan
| ex13b.c problem to run |
Posted: Tue May 15, 2012 1:51 am |
Dear all,
I bought CCS 3.3V Ethernet Controler development kit.
I tried to run ex13b.c file (without change anything) but i get errors as follow:
>>> Warning 201 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 189(1,1): Assignment inside relational expression
--- Info 300 "C:\Program Files\PICC\drivers\string.h" Line 15(7,13): More info: First Declaration of strupr
*** Error 31 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 302(1,2): Identifier is already used in this scope
*** Error 48 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 306(7,8): Expecting a (
*** Error 48 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 306(9,10): Expecting a (
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 307(5,10): Expecting a declaration
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 307(10,11): Expecting a declaration
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 307(12,13): Expecting a declaration
*** Error 48 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 307(15,16): Expecting a (
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 307(17,18): Expecting a declaration
*** Error 48 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 307(18,19): Expecting a (
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 307(21,22): Expecting a declaration
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 308(5,6): Expecting a declaration
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(9,11): Expecting a declaration
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(12,13): Expecting a declaration
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(14,15): Expecting a declaration
*** Error 48 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(17,18): Expecting a (
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(20,23): Expecting a declaration
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(24,26): Expecting a declaration
*** Error 48 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(29,30): Expecting a (
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(32,35): Expecting a declaration
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(35,36): Expecting a declaration
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 309(37,38): Expecting a declaration
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 310(13,14): Expecting a declaration
*** Error 48 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 310(16,17): Expecting a (
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 310(19,20): Expecting a declaration
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 310(20,23): Expecting a declaration
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 310(24,25): Expecting a declaration
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 310(26,29): Expecting a declaration
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 310(29,30): Expecting a declaration
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 310(30,31): Expecting a declaration
*** Error 48 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 311(5,6): Expecting a (
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 311(8,9): Expecting a declaration
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 312(5,6): Expecting a declaration
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 313(5,11): Expecting a declaration
*** Error 48 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 313(12,13): Expecting a (
*** Error 43 "D:\Elektronika\My Designs\c++\Marcin_CCS\Testy\TCP Server\tcpip\helpers.c" Line 314(1,2): Expecting a declaration
35 Errors, 1 Warnings.
Build Failed.
I don't understand because i checked and this functions have declaration.
Best Regards,
Martin |
stoyanoff
Posted: Tue May 15, 2012 4:27 am |
Paste lines 302 to 314. I suppose you've made an error with copying the code.
Stoyanoff |
Requan
Posted: Tue May 15, 2012 5:45 am |
Thanks for reply.
Here You are:
| Code: | char *strupr (char *s)
char c;
char *t;
t = s;
while( (c = *t) )
if ( (c >= 'a' && c <= 'z') )
*t -= ('a' - 'A');
t++;
return s;
I use PIC 18F67J60 and of course set proper value in ccstcpip.h.
I didn't change anything. i run example only. |
Requan
Posted: Thu May 17, 2012 3:17 am |
| When I remove this function it solved problem. |
stoyanoff
Posted: Thu May 17, 2012 3:37 am |
It's impossible the name of a function to be a pointer. Remove the "*" from the name of the function.
Stoyanoff |
jeremiah
Posted: Thu May 17, 2012 6:14 am |
| He's returning a char*...the function name is fine. Based on the errors though, it sounds like strupr is already defined somewhere. Try just changing the name to strupr2 and see if it compiles. |
Requan
Posted: Tue May 22, 2012 7:34 am |
jeremiah
Yes it helps. Thank You |
