Ultrasonic Distance measuring
taher
PostPosted: Mon Mar 12, 2012 7:07 pm     Reply with quote
Hi everyone,
I am using Ping Ultrasonic sensor and trying to measure the distance of obstacle and I searched for that in the forum before I post that.
So I hope someone can help me.
(sorry for my english not that well)
This is my code:
#include <16F877.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOPUT                    //No Power Up Timer
#use delay(clock=40000000)
#include <LCD.C>
#define trig pin_B1
int16 front_mont,mesure;
int valid=0;
#int_CCP1
void  CCP1_isr(void)
   front_mont=CCP_1;
   valid=1;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_ccp1(CCP_CAPTURE_RE);
   enable_interrupts(INT_CCP1);
   // TODO: USER CODE!!
   while(true)
         output_high(trig);                         // ping the sonar
         delay_us(5);                            // sending 5us pulse
         output_low(trig);
         if(valid)
               mesure=front_mont*0.000272;//0.000272=2*10^-7*8*170
               valid=0;
               set_timer1(0);
         printf(lcd_putc,"\fDistance=%Lu",mesure);
bkamen
Re: Ultrasonic Distance measuring
PostPosted: Mon Mar 12, 2012 7:21 pm     Reply with quote
taher wrote:
Hi everyone,
Try again.
Use "ultrasonic range"
and you're going to find LOTS of results.
-ben
gpsmikey
PostPosted: Mon Mar 12, 2012 8:42 pm     Reply with quote
One thing to keep in mind is that most ultrasonic ranging is going to return the closest object (even if that was not what you wanted) - it will see the first echo. That is why I hate digital depth sounders - fish, kelp, thermocline all give false readings of "too shallow". That may not be an issue in your case, but be aware of the problem if it applies.
mikey
mikey
drh
PostPosted: Tue Mar 13, 2012 8:55 am     Reply with quote
Another "minor" error. You have specified 40Mhz in the #use delay statement.
This chip has a maximum speed of 20Mhz. Did you intend to use 4Mhz?
David
PostPosted: Tue Mar 13, 2012 9:30 am     Reply with quote
is SO true!!
REAL range finder systems use log amps to process multiple return signals of decreasing amplitude pulses and then adds analog differentiation to discriminate within a specified time window to show MULTIPLE returns
not just the closest .
MOST importantly - such designs DO NOT use anything so utterly primitive as a PING sensor either Very Happy Very Happy Smile Smile
i am hearing echoes of a very VERY familiar school project leaking out in this post
taher
PostPosted: Tue Mar 13, 2012 6:37 pm     Reply with quote
thanks for reply
but my ultrasonic sensor send pulse of 40khz that's why i used
"#use delay=40000000"
SherpaDoug
PostPosted: Tue Mar 13, 2012 6:46 pm     Reply with quote
The PIC processor doesn't care what frequency the ultrasonics run at. That #use delay tells the compiler how fast the PIC is running, ie. what the PIC clock speed is.
gpsmikey
PostPosted: Tue Mar 13, 2012 8:01 pm     Reply with quote
taher wrote:
thanks for reply
Even if that was an issue, 40khz is NOT the same as 40mhz (which is what you specified for the clock). As SherpaDoug points out though, they are not related. It is possible over a limited range to only accept echos within a window along the lines of what asmboy indicated. That is actually a feature that they have started adding to some of the high end camera lenses - you can limit the autofocus range so it can lock faster instead of trying to hunt through the whole range (usually going in the wrong direction first Evil or Very Mad )
mikey
