taher
| Ultrasonic Distance measuring |
Posted: Mon Mar 12, 2012 7:07 pm |
Hi everyone,
I am using Ping Ultrasonic sensor and trying to measure the distance of obstacle and I searched for that in the forum before I post that.
So I hope someone can help me.
(sorry for my english not that well)
This is my code:
#include <16F877.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#use delay(clock=40000000)
#include <LCD.C>
#define trig pin_B1
int16 front_mont,mesure;
int valid=0;
#int_CCP1
void CCP1_isr(void)
front_mont=CCP_1;
valid=1;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_ccp1(CCP_CAPTURE_RE);
enable_interrupts(INT_CCP1);
// TODO: USER CODE!!
while(true)
output_high(trig); // ping the sonar
delay_us(5); // sending 5us pulse
output_low(trig);
if(valid)
mesure=front_mont*0.000272;//0.000272=2*10^-7*8*170
valid=0;
set_timer1(0);
printf(lcd_putc,"\fDistance=%Lu",mesure);
bkamen
Joined: 07 Jan 2004 Posts: 1617 Location: Central Illinois, USA
| Re: Ultrasonic Distance measuring |
Posted: Mon Mar 12, 2012 7:21 pm |
| taher wrote: | Hi everyone,
Try again.
Use "ultrasonic range"
and you're going to find LOTS of results.
-ben _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
gpsmikey
Posted: Mon Mar 12, 2012 8:42 pm |
One thing to keep in mind is that most ultrasonic ranging is going to return the closest object (even if that was not what you wanted) - it will see the first echo. That is why I hate digital depth sounders - fish, kelp, thermocline all give false readings of "too shallow". That may not be an issue in your case, but be aware of the problem if it applies.
mikey _________________ mikey
drh
Joined: 12 Jul 2004 Posts: 194 Location: Hemet, California USA
Posted: Tue Mar 13, 2012 8:55 am |
Another "minor" error. You have specified 40Mhz in the #use delay statement.
This chip has a maximum speed of 20Mhz. Did you intend to use 4Mhz? _________________ David |
Posted: Tue Mar 13, 2012 9:30 am |
| Quote: |
is SO true!!
REAL range finder systems use log amps to process multiple return signals of decreasing amplitude pulses and then adds analog differentiation to discriminate within a specified time window to show MULTIPLE returns
not just the closest .
MOST importantly - such designs DO NOT use anything so utterly primitive as a PING sensor either
i am hearing echoes of a very VERY familiar school project leaking out in this post |
taher
Posted: Tue Mar 13, 2012 6:37 pm |
thanks for reply
but my ultrasonic sensor send pulse of 40khz that's why i used
"#use delay=40000000" |
SherpaDoug
Posted: Tue Mar 13, 2012 6:46 pm |
The PIC processor doesn't care what frequency the ultrasonics run at. That #use delay tells the compiler how fast the PIC is running, ie. what the PIC clock speed is. _________________ The search for better is endless. Instead simply find very good and get the job done. |
gpsmikey
Posted: Tue Mar 13, 2012 8:01 pm |
| taher wrote: | thanks for reply
Even if that was an issue, 40khz is NOT the same as 40mhz (which is what you specified for the clock). As SherpaDoug points out though, they are not related. It is possible over a limited range to only accept echos within a window along the lines of what asmboy indicated. That is actually a feature that they have started adding to some of the high end camera lenses - you can limit the autofocus range so it can lock faster instead of trying to hunt through the whole range (usually going in the wrong direction first ) _________________ mikey
