Help to fix this Error "undefined identifier"
nirvan
PostPosted: Sun Mar 11, 2012 3:52 pm     Reply with quote
Hello everybody, I want you to help me to fix this problem. I made a program but I don't understand why pic c don't identify these three instructions:
* setup_power_pwm_pins(PWM_COMPLEMENTARY, PWM_COMPLEMENTARY, PWM_OFF, PWM_OFF);
* set_power_pwm0_duty();
* setup_power_pwm(PWM_FREE_RUN|PWM_DEAD_CLOCK_DIV_2, 1, 0, POWER_PWM_PERIOD, 0, 1,4);
Are there related to some library.....? give me a solution please.
PostPosted: Sun Mar 11, 2012 4:02 pm     Reply with quote
Which PIC are you trying to use?
Which version of the compiler ??
Do BOTH the PIC and compiler have those functions ??
gpsmikey
PostPosted: Sun Mar 11, 2012 4:03 pm     Reply with quote
Since you don't provide a lot of helpful information, we are shooting in the dark, but did you include the correct header file for your processor of choice?
mikey
Mike Walne
Follow the CCS forum guide
PostPosted: Mon Mar 12, 2012 2:46 am     Reply with quote
Post a SHORT, but complete, compilable code which shows the problem.
In other words, reduce your code to as FEW lines as possible, but still giving the errors. We don't want to wade through mountains of code.
Probability is someone here will help you.
Include your PIC and version No.
Mike
nirvan
PostPosted: Mon Mar 12, 2012 1:10 pm     Reply with quote
Hello, I am using pic 16f877a
and for the compiler I am using pic c 4.084.
I don't know for the pic but I am sure that these instructions are functional in the compiler. I find them in the manual of pic c
nirvan
PostPosted: Mon Mar 12, 2012 1:18 pm     Reply with quote
#include "D:\PFA\PICC\sine2.h"
#int_TIMER1
void  TIMER1_isr(void)
#int_TIMER2
void  TIMER2_isr(void)
#define POWER_PWM_PERIOD 999
long const duty[100] =
{120,240,360,519,639,759,879,999,1118,1238,
1359,1479,1598,1718,1798,1918,2038,2158,2238,2358,
2438,2557,2637,2717,2837,2917,2997,3077,3157,3237,
3317,3357,3437,3516,3556,3596,3676,3716,3756,3796,
3836,3876,3916,3916,3916,3916,3916,3916,3916,3916,
3916,3916,3916,3916,3916,3916,3916,3876,3836,3796,
3756,3716,3676,3596,3556,3516,3437,3357,3317,3237,
3157,3077,2997,2917,2837,2717,2637,2557,2438,2358,
2238,2158,2038,1918,1798,1718,1598,1479,1359,1239,
1119,999,879,759,639,519,360,240,120,120
long i,d0,d1,d2,j,k;
void duty_int()
if(i>99)
{ d1 = 120;
  i =0; }
 {d1 = duty[i];
  i++;
  d0 = 120;}
 {d0 = duty[i];
   i++;
   d1 = 120;
   j = 0; }
set_power_pwm0_duty(d0);
set_power_pwm2_duty(d1);
float v;
int d3 = 50;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
   setup_timer_2(T2_DIV_BY_1,0,1);
   setup_vref(FALSE);
   enable_interrupts(INT_RTCC);
   i=0;
   j=100;
   k=132;
d0 = 120;
d1 = 120;
ENABLE_INTERRUPTS(GLOBAL);
ENABLE_INTERRUPTS(INT_timer0);
    while(1){ }
PostPosted: Mon Mar 12, 2012 1:42 pm     Reply with quote
Do a Google search for the following string, and you will see some PICs
that have the Power Control PWM module:
site:microchip.com "power control pwm" type:pdf
The 16F877A does not have it.
dyeatman
PostPosted: Mon Mar 12, 2012 1:48 pm     Reply with quote
I don't believe Power PWM is available on PIC16F chips.
Whoops, a little later than PCM on this one...
Google and Forum Search are some of your best tools
nirvan
thank
PostPosted: Mon Mar 12, 2012 2:35 pm     Reply with quote
thank you guys Smile
