nirvan
| Help to fix this Error "undefined identifier" |
Posted: Sun Mar 11, 2012 3:52 pm |
Hello everybody, I want you to help me to fix this problem. I made a program but I don't understand why pic c don't identify these three instructions:
* setup_power_pwm_pins(PWM_COMPLEMENTARY, PWM_COMPLEMENTARY, PWM_OFF, PWM_OFF);
* set_power_pwm0_duty();
* setup_power_pwm(PWM_FREE_RUN|PWM_DEAD_CLOCK_DIV_2, 1, 0, POWER_PWM_PERIOD, 0, 1,4);
Are there related to some library.....? give me a solution please. |
Joined: 01 Jul 2010 Posts: 9652 Location: Greensville,Ontario
Posted: Sun Mar 11, 2012 4:02 pm |
Which PIC are you trying to use?
Which version of the compiler ??
Do BOTH the PIC and compiler have those functions ?? |
gpsmikey
Posted: Sun Mar 11, 2012 4:03 pm |
Since you don't provide a lot of helpful information, we are shooting in the dark, but did you include the correct header file for your processor of choice? _________________ mikey
Mike Walne
| Follow the CCS forum guide |
Posted: Mon Mar 12, 2012 2:46 am |
Post a SHORT, but complete, compilable code which shows the problem.
In other words, reduce your code to as FEW lines as possible, but still giving the errors. We don't want to wade through mountains of code.
Probability is someone here will help you.
Include your PIC and version No.
Mike |
nirvan
Posted: Mon Mar 12, 2012 1:10 pm |
| temtronic wrote: | Which PIC are you trying to use?
Hello, I am using pic 16f877a
and for the compiler I am using pic c 4.084.
I don't know for the pic but I am sure that these instructions are functional in the compiler. I find them in the manual of pic c |
nirvan
Posted: Mon Mar 12, 2012 1:18 pm |
| gpsmikey wrote: | | Since you don't provide a lot of helpful information, we are shooting in the dark, but did you include the correct header file for your processor of choice? |
#include "D:\PFA\PICC\sine2.h"
#int_TIMER1
void TIMER1_isr(void)
#int_TIMER2
void TIMER2_isr(void)
#define POWER_PWM_PERIOD 999
long const duty[100] =
{120,240,360,519,639,759,879,999,1118,1238,
1359,1479,1598,1718,1798,1918,2038,2158,2238,2358,
2438,2557,2637,2717,2837,2917,2997,3077,3157,3237,
3317,3357,3437,3516,3556,3596,3676,3716,3756,3796,
3836,3876,3916,3916,3916,3916,3916,3916,3916,3916,
3916,3916,3916,3916,3916,3916,3916,3876,3836,3796,
3756,3716,3676,3596,3556,3516,3437,3357,3317,3237,
3157,3077,2997,2917,2837,2717,2637,2557,2438,2358,
2238,2158,2038,1918,1798,1718,1598,1479,1359,1239,
1119,999,879,759,639,519,360,240,120,120
long i,d0,d1,d2,j,k;
void duty_int()
if(i>99)
{ d1 = 120;
i =0; }
{d1 = duty[i];
i++;
d0 = 120;}
{d0 = duty[i];
i++;
d1 = 120;
j = 0; }
set_power_pwm0_duty(d0);
set_power_pwm2_duty(d1);
float v;
int d3 = 50;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_2(T2_DIV_BY_1,0,1);
setup_vref(FALSE);
enable_interrupts(INT_RTCC);
i=0;
j=100;
k=132;
d0 = 120;
d1 = 120;
ENABLE_INTERRUPTS(GLOBAL);
ENABLE_INTERRUPTS(INT_timer0);
while(1){ }
Posted: Mon Mar 12, 2012 1:42 pm |
Do a Google search for the following string, and you will see some PICs
that have the Power Control PWM module:
| Quote: |
site:microchip.com "power control pwm" type:pdf |
The 16F877A does not have it. |
Posted: Mon Mar 12, 2012 1:48 pm |
I don't believe Power PWM is available on PIC16F chips.
Whoops, a little later than PCM on this one... _________________ Google and Forum Search are some of your best tools |
nirvan
| thank |
Posted: Mon Mar 12, 2012 2:35 pm |
thank you guys  |
