1980best
| 24FV32KA pwm ...GOOD.. |
Posted: Sun Jan 22, 2012 2:18 pm |
SUPER............
#include <24FV32KA302.h>
#device ADC=12
#FUSES PR //Primary Oscillator
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOOSCIO
#use delay(clock=20000000) // hs 20mhz osc
delay_ms(10);
SET_TRIS_A(0x0000);
SET_TRIS_B(0x0000);
setup_compare(1,COMPARE_PWM_EDGE | COMPARE_SYSTEM_CLOCK | COMPARE_TRIG_SYNC_SELF);
set_pwm_period(1, 10000);
set_pwm_duty (1, 5000);
while(TRUE);
razor1983m
| Re: 24FV32KA302 pwm, timer, please help |
Posted: Mon Jan 23, 2012 8:52 am |
| hımm |
Posted: Mon Jan 23, 2012 8:56 am |
Best help is for you to press F11 when your project is open! Consult the nice onscreen HELP file that CCS supplies.
Hint...look under 'Builtin Functions'....scroll down to set_pwm...........and read! |
