24FV32KA pwm ...GOOD..
1980best
PostPosted: Sun Jan 22, 2012 2:18 pm     Reply with quote
SUPER............
#include <24FV32KA302.h>
#device ADC=12
#FUSES PR                       //Primary Oscillator
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOOSCIO
#use delay(clock=20000000)  // hs 20mhz osc
delay_ms(10);
SET_TRIS_A(0x0000);
SET_TRIS_B(0x0000);
setup_compare(1,COMPARE_PWM_EDGE | COMPARE_SYSTEM_CLOCK | COMPARE_TRIG_SYNC_SELF);
   set_pwm_period(1, 10000);
   set_pwm_duty   (1,   5000);
while(TRUE);
razor1983m
Re: 24FV32KA302 pwm, timer, please help
PostPosted: Mon Jan 23, 2012 8:52 am     Reply with quote
hımm
PostPosted: Mon Jan 23, 2012 8:56 am     Reply with quote
Best help is for you to press F11 when your project is open! Consult the nice onscreen HELP file that CCS supplies.
Hint...look under 'Builtin Functions'....scroll down to set_pwm...........and read!
