karti.m
| how to use eeprom read and write commands..any one help me. |
Posted: Sat Dec 17, 2011 5:22 am |
Actually I want to save the value of a variable at the instant of power failure. Again when power came the stored value must read from memory and used for output.
write_EEPROM(add,inc1);
write_EEPROM(add1,dec1);
l= read_EEPROM(add1);
m= read_EEPROM(add);
I used this in my coding but its not working.
It returns only 0. |
bkamen
Posted: Sat Dec 17, 2011 1:17 pm |
We need to know more than this.
Give us a FULL but SMALL example we can compile.
Include in your reply the version of compiler.
Your example should include the device as without that info, we can't tell if your device even has EEPROM...
Posted: Sat Dec 17, 2011 4:00 pm |
Also, how are you detecting that power has failed?.
At what voltage?.
How long will power still be high enough to support the EEPROM write operation after this?.
karti.m
| regarding eeprom |
Posted: Mon Dec 19, 2011 10:04 am |
| am using pic16f873a,its a 5V device... |
karti.m
Posted: Tue Dec 20, 2011 10:21 am |
| thanx a lot for ur links... |
