Arithmetic error in sum of int array member and float
RF_Developer
PostPosted: Wed Aug 31, 2011 7:17 am     Reply with quote
I have just sent in a bug report regarding an arithmetic error on PCWH 4.124 :-( This is just for people's information and if they wish to check if other complier versions show the fault.
Its a code generation error that means that a + b != b + a in some situations. It also relates to casting which is something I've been writing a fair bit about. I found this fault when trying to debug temperature compensating code for multiple channel GaAs FET bias generation, which explains the arrays of arrays. And no, I use longer, more readable variable names. I have shortened them for this test example.
Here's my test source.
#include <18F6722.h>
#device ICD=TRUE
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES EC                       //External clock with CLKOUT
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES PUT                      //Power Up Timer
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#FUSES BBSIZ1K                  //1K words Boot Block size
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#use delay(clock=10000000)
float T_D;
float T_C[2] = { 0.0f, 1.0f };
int D;
signed int16 V_C[2][2] = { { 4000, 4000 }, { 4000, 4000 } };
signed int16 V;
signed int16 C[2] = { 4000, 4000 };
signed int16 E = 4000;
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_timer_4(T4_DISABLED,0,1);
   setup_vref(FALSE);
D = 1;
T_D = 1.0f;
      // This code shows that on PCWH 4.124 a + b != b + a if a is an integer array and b is a float.
      // This is the original form of the code where I saw the problem.
      V = V_C[0][D] + (T_D * T_C[D]);  // V should be 4000 if D = 0, 4001 if D = 1. V is always 0 :-(
      // Reversing the order of the sum solves the problem.
      V = (T_D * T_C[D]) + V_C[0][D];  // V should be 4000 if D = 0, 4001 if D = 1. V is correct.
      // Try doing it in stages.
      V = V_C[0][D];                   // V should be 4000. V is correct.
      V += (T_D * T_C[D]);             // V should be 4000 if D = 0, 4001 if D = 1.  V is correct.
      // Possibly arithmetic error is related to double indexing (2D array). So try a simple 1D array.
      V = C[D] + (T_D * T_C[D]);       // V should be 4000 if D = 0, 4001 if D = 1. V is always 0 :-(
      V = (T_D * T_C[D]) + C[D];       // V should be 4000 if D = 0, 4001 if D = 1. V is correct.
      // Both array versions had the fault. Try simple varible.
      V = E + (T_D * T_C[D]);          // V should be 4000 if D = 0, 4001 if D = 1. V is correct!
      V = (T_D * T_C[D]) + E;          // V should be 4000 if D = 0, 4001 if D = 1. V is correct.
      // Simple variable worked OK.
      // This is the simplest expression that shows the fault.
      V = C[D] + T_D;       // V should be 4001. V is always 0 :-(
      V = T_D + C[D];       // V should be 4001. V is correct.
      // Explicit casting solves the problem. This suggests the problem is related to
      // type determination in implicit/automatic casting.
      V = C[D] + (signed int16)T_D;       // V should be 4001. V is correct.
      V = (signed int16)T_D + C[D];       // V should be 4001. V is correct.
After all that I hope I've not done anything stupid :-(
RF Developer
newguy
PostPosted: Wed Aug 31, 2011 7:24 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?p=76060
Came across something similar 4.5 years ago. In my case it turned out that the order of the variables/constants was important.
PostPosted: Thu Sep 01, 2011 1:38 am     Reply with quote
The test program has same results with PCH V4.078, apparently it's an old bug.
Your post also shows, that some things haven't changed much at CCS.
