RF_Developer
| Arithmetic error in sum of int array member and float |
Posted: Wed Aug 31, 2011 7:17 am |
I have just sent in a bug report regarding an arithmetic error on PCWH 4.124 :-( This is just for people's information and if they wish to check if other complier versions show the fault.
Its a code generation error that means that a + b != b + a in some situations. It also relates to casting which is something I've been writing a fair bit about. I found this fault when trying to debug temperature compensating code for multiple channel GaAs FET bias generation, which explains the arrays of arrays. And no, I use longer, more readable variable names. I have shortened them for this test example.
Here's my test source.
| Code: | #include <18F6722.h>
#device ICD=TRUE
#FUSES EC //External clock with CLKOUT
#FUSES PUT //Power Up Timer
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES BBSIZ1K //1K words Boot Block size
#use delay(clock=10000000)
float T_D;
float T_C[2] = { 0.0f, 1.0f };
int D;
signed int16 V_C[2][2] = { { 4000, 4000 }, { 4000, 4000 } };
signed int16 V;
signed int16 C[2] = { 4000, 4000 };
signed int16 E = 4000;
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_4(T4_DISABLED,0,1);
setup_vref(FALSE);
D = 1;
T_D = 1.0f;
// This code shows that on PCWH 4.124 a + b != b + a if a is an integer array and b is a float.
// This is the original form of the code where I saw the problem.
V = V_C[0][D] + (T_D * T_C[D]); // V should be 4000 if D = 0, 4001 if D = 1. V is always 0 :-(
// Reversing the order of the sum solves the problem.
V = (T_D * T_C[D]) + V_C[0][D]; // V should be 4000 if D = 0, 4001 if D = 1. V is correct.
// Try doing it in stages.
V = V_C[0][D]; // V should be 4000. V is correct.
V += (T_D * T_C[D]); // V should be 4000 if D = 0, 4001 if D = 1. V is correct.
// Possibly arithmetic error is related to double indexing (2D array). So try a simple 1D array.
V = C[D] + (T_D * T_C[D]); // V should be 4000 if D = 0, 4001 if D = 1. V is always 0 :-(
V = (T_D * T_C[D]) + C[D]; // V should be 4000 if D = 0, 4001 if D = 1. V is correct.
// Both array versions had the fault. Try simple varible.
V = E + (T_D * T_C[D]); // V should be 4000 if D = 0, 4001 if D = 1. V is correct!
V = (T_D * T_C[D]) + E; // V should be 4000 if D = 0, 4001 if D = 1. V is correct.
// Simple variable worked OK.
// This is the simplest expression that shows the fault.
V = C[D] + T_D; // V should be 4001. V is always 0 :-(
V = T_D + C[D]; // V should be 4001. V is correct.
// Explicit casting solves the problem. This suggests the problem is related to
// type determination in implicit/automatic casting.
V = C[D] + (signed int16)T_D; // V should be 4001. V is correct.
V = (signed int16)T_D + C[D]; // V should be 4001. V is correct.
After all that I hope I've not done anything stupid :-(
RF Developer |
newguy
Posted: Thu Sep 01, 2011 1:38 am |
The test program has same results with PCH V4.078, apparently it's an old bug.
| Quote: | | Came across something similar 4.5 years ago. |
Your post also shows, that some things haven't changed much at CCS. |
