lukyluke
| Strange compilation problem |
Posted: Fri Feb 18, 2011 1:32 pm |
Hello!
I'm working on a very simple project with a 12F629 but I'm stuck in a problem I can't understand...
C Code:
| Code: | #include "C:\ServoDecoder_PIC\servodecoder.h"
void main() {
while(1) {
output_bit(PIN_A0, !input(PIN_A0));
H Code:
| Code: | #include <12F629.h>
#FUSES BANDGAP_HIGH |
When I compile, here's the ASM:
| Code: | 0000: MOVLW 00
0001: MOVWF 0A
0002: GOTO 004
0003: NOP
0004: CALL 3FF |
As you can see, it calls the last (3FF) address of program memory and stops... do you see any mistakes in my H file?
If I remove #FUSES declarations, the assembly is ok:
0001: MOVWF 0A
0002: GOTO 018
0003: NOP
.................... void main() {
0018: CLRF 04 |
Thanks! |
Posted: Fri Feb 18, 2011 1:41 pm |
| What's your compiler version ? |
lukyluke
Posted: Fri Feb 18, 2011 1:44 pm |
Hello
4.057, with a further investigation it seems INTRC_IO is the problem, if I change to XT (for example) the ASM generated is correct... |
Posted: Fri Feb 18, 2011 1:57 pm |
It works for me. I installed vs. 4.057, and took your code and pasted it
into an MPLAB project as one program (no separate servodecoder.h file).
The .LST file doesn't stop at 0004.
CCS PCM C Compiler, Version 4.057, xxxxx 18-Feb-11 11:55
Filename: 12F629_Test.lst
ROM used: 55 words (5%)
Largest free fragment is 969
RAM used: 6 (9%) at main() level
7 (11%) worst case
Stack: 1 locations
0000: MOVLW 00
0001: MOVWF 0A
0002: GOTO 004
0003: NOP
0004: CALL 3FF
0005: BSF 03.5
0006: MOVWF 10
0007: MOVLW 00
0008: MOVWF 0A
0009: GOTO 01E
#include <12F629.h>
#FUSES BANDGAP_HIGH
void main() {
while(1) {
lukyluke
Posted: Fri Feb 18, 2011 2:03 pm |
thanks for your support... very strange I've just copy&paste your source code in my C file, and here's the result:
| Code: | CCS PCM C Compiler, Version 4.057, xxxxx 18-feb-11 21.01
Filename: C:\ServoDecoder_PIC\servodecoder.lst
7 (11%) worst case
Stack: 1 locations
0000: MOVLW 00
0001: MOVWF 0A
0002: GOTO 004
0003: NOP
0004: CALL 3FF
0 |
lukyluke
Posted: Fri Feb 18, 2011 2:11 pm |
| mmm maybe I wasn't clear in my explanation: my ASM source doesn't stop at 0004, but the instruction at that address make a CALL to the last memory address (CALL 3FF) and the program stops (with a simulator or with a "real" circuit the led doesn't blink) |
Posted: Fri Feb 18, 2011 3:44 pm |
And to explain 'why'. The chip's come from the factory, with a single instruction at address 0x3FF, 'preprogrammed' by the manufacturer. The instruction is a RETLW, returning a value designed to calibrate the internal oscillator. This is called the 'OSCCAL' (oscillator calibration) value.
Yours has had this value erased.
The thread PCM programmer points you to, shows how to put a 'mid range' value back into this location, but understand that the calibration will have been lost, so frequencies won't be that good.
For 'future reference', look into your programmer settings. there should be an option to 'save OSCCAL', or 'preserve calibration', and you need to select this, otherwise you will do the same to the next chip you try....
lukyluke
Posted: Sat Feb 19, 2011 4:55 am |
Friends,
Thanks for your suggestion and the explanation (very interesting, I never investigated about the OSCCAL feature): it worked fine and I was able to find - in my software - the flag to preserve the value at 0x3FF address when programming my HEX. |
